Popcorn a300
Old 03-05-2012, 12:50 AM   #661
Rom Rom is offline
Thanks: Gave 41, Got 735
Originally Posted by LightBright View Post
Please can someone tell me if you can connect a DVD-ROM to the A-800 in order to play commercial discs? So far I only know of two players which support this (both HiMedia players). Thanks
There is no A800 but yes, you can connect an external USB DVD-ROM to the A2xx & A300 series players. Exactly which drives work I do not know but I know some users have done this.
The NetworkedMediaTank forum or the Wiki will have more info.
Old 03-05-2012, 4:51 PM   #662
Originally Posted by KevG123 View Post
Other than audio drop outs, that played fine
That's not promising. Does it still happen with the latest firmware?
Old 03-05-2012, 5:42 PM   #663
Thanks: Gave 83, Got 9
Managed to fix my problem. Plugged a USB drive in and NMT wizard appeared. Was then able to select and format my internal HDD! Odd but it seems to have worked. Currently copying some media to it. Next stop, YAMJ!
Old 03-05-2012, 5:55 PM   #664
KevG123's Avatar
Thanks: Gave 31, Got 47
Glad you got it sorted
would recommend you start off getting the built in NMJ set up first, then you can progress to YAMJ
Setting up YAMJ for the first time can be a bit daunting but there is plenty of help around - especially on the NMT forums
Old 08-05-2012, 1:18 AM   #665
Rom Rom is offline
NMJToolbox2 Update: NMJ Toolbox | The Original Editor for The PopcornHour NMJ!
1.0.2.6
Changes:
Changed image quality of preview images in the 'Browse Images' window for the MovieDB when using API3.0 setting (makes setup/browsing faster but the image downloaded to save is still high quality).
Fixed clicking the 'Edit Keywords' button causes an application exception.
Old 12-05-2012, 12:08 PM   #666
Thanks: Gave 129, Got 15
what is the best way to get episodes marked as watched on popcorn 300 series
Old 12-05-2012, 2:40 PM   #667
Rom Rom is offline
Are you using the NMJ?
If so you can use my NMJToolbox, right click on the entry and select 'Mark as Watched'.
You can also just play a second of the episode in NMJ and it will marked it as watched.
thorley37 (12-05-2012)
Old 12-05-2012, 10:11 PM   #668
Rom Rom is offline
1.0.2.7 released
Changes:
Added reporting ability to scan the paths in the DB and report Audio or Video files that are not in the database.
Disabled the report button when a DB is not opened.
Fixed when changing the TVDB ID and/or IMDB TTID on TV series & seasons, changing from the node and moving back the IDs had not changed (display only issue)
*I have done limited testing with my setup(s) for the scan facility. I would be particularly interested to hear from people who have multiple PATH settings to see if it scans ALL of their paths. Also let me know if there are any files that you would have expected it to pick up but missed etc.
Old 24-05-2012, 10:02 PM   #669
having problems with the a300 and wanted to find out if anyone else is having a simular problem.
Problem 1
Background: my dvds are recorded in the VIDEO_TS RIPED FORMAT. They are installed in an external drive connected to my windows 7 computer. The files are named such as western or sifi.
for example i have a file called westerns in that file i have folders that are named for the movie they contain, and in the folder i have the VIDEO_TS DATA.
when i brows the file western from my a300 i can see the folders of the movies. when i select the movie i can scan the data base and see the movie art work and info, and can select the correct jpeg and download.
when you look at the western folder on the pc you see the jep and when you select the folder from the a300 you see the art work also no problems.
The problem occures when you creat a jukebox (nmj). I go to my a300 and create a jukebox and it scans the files in the folder example western. once the scan is completed i go to the jb and see the art work it selected . For movies that it could not find art work or if the art work is incorrect i to to the edit in JB and unlkie the edit in the brows mode the name of the movie does not appear ??? when i type in the movie name it goes out on the network and it does find the correct art work. when i attempt to download the correct art it goes into a download and i wait and wait and wait it then comes back to me and tells me it was unable to download it.
ive tested this process and find that if you have a movie that is ripped in the iso format it works fine. If however you have a movie in the VIDEO_TS format it fails every time.
the movies always play just find and you get full dvd menues when played . Im just one of those that wants my data base correct and canot edit its errors.
please let me know if anyone that has a a300 has the same problem.
contacted the popcorn hour tech support and they said they think it may be a bug . Well its a bug or i have a problem with my computer.
please give me feed back
Forgot about the second problem
problem 2
i find that the a300 is hanging up and cannot find my network at times.
When the problem occures i find that i cannot connect to my computer from the a300 to my windows 7 computer.
So far the only way to solve the problem is to reboot my computer that always fixes the problem.
The problem occures when i am updateing my a300 JB and at the same time doing things on my computer. It looks like the a300 is unable to get access to the computer and locks up . I understand that their may be a conflect because im playing a game at the time but my issue is whether their is a fix other than rebooting my computer . Ive unpluged the cat 5 cable to the a300 powered it off noting solves the problem other than rebooting the computer. wanted to find out if anyone has a solution to this problem.
Old 25-05-2012, 10:39 AM   #670
KevG123's Avatar
Lets look at the first problem first
Can you post a few of your movie file names please - the ones nmj can't find the artwork for
Also - can you confirm you are running with the latest firmware
Old 25-05-2012, 8:19 PM   #671
not sure if you understand what the issue is.
When im in the jukebox i select the movie and type in the name of the move in the edit window. the a300 goes out on the internet and finds the movie info including the art work. when i try to click the download it will not bring in the art for the jpeg.
Their is no issue with it finding the art work the above takes place on all my movies and i have many.
when you go through the same procedure in the browse mode not using the nmj the edit again finds the movie and downloads it.
Again the edit does not work on the jukebox nmj at all. even movies where the nuj found the art work i cannot edit it .
ive tried this on many movies and the edit for VIDEO_TS movies in nmj does not work.. The edit for the same movies using the browser edit always works.
you Can however edit in the nmj movies ISO or AVI no problem.
Do you have VIDEO_TS riped dvd's and are you able to edit them using the Jukebox nmj editor????????
Old 25-05-2012, 11:46 PM   #672
KevG123's Avatar
use Rom's nmjtoolbox
see link in posts abobe
Old 04-06-2012, 4:53 PM   #673
Thanks: Gave 6, Got 3
I currently have a WDTVLiveHub and the new WD Live Streamer.
When I eventually get the A-300 I don't mind writing up a comparison/first impressions if anyone is interested.
Hi, what are view and experiences of using the A300over the WD TV live?
Be nice t here your comparrison, as I sort of in a similar postion to your self,but not yet ordered anything.
Old 04-06-2012, 6:32 PM   #674
KevG123's Avatar
The main reason I went for the PCH was because of the built in jukebox in comparison to the WD
I would say picture and sound wise there's not much in it (except the WD doesnt do DTS-HD and the PCH does)
Also, the NMT forums are great support for the PCH and recently I've started using YAMJ on the PCH which is pretty cool
Started to get a bit fed up with the WD fw updates as it was a bit of a lottery as to what would be fixed vs what would be broken
ALIEN1X (05-06-2012)
Old 05-06-2012, 12:14 PM   #675
Thanks for the advise. However, can vlc potable be loaded into the A300, as its a linux based player will it work?
I need VLC to work on a hardware media player so I can use my old topfield pvr recordings to play thru it.
If not, then can on stream from vlc on a pc to the A300 and view the video from from there.
Old 06-06-2012, 8:13 AM   #676
Thanks: Gave 199, Got 377
Use this to convert the .rec to .ts files and they'll play on the PCH:
Paul's web page
Old 06-06-2012, 2:02 PM   #677
Paul's web page
I will try it.Is there any loss in quality when coverting from .rec to .ts?
Old 06-06-2012, 2:09 PM   #678
Is there a diffrence in audio and video quality between popbox v8 and popcorn A300 and any other pros and cons between them?
Can the A300 be used without an internal hardirve so that one can use just an external 1-2tb usb hdd?
I have noted there cheaper european versions of popbox v8 for 103GBP & A300 for 178GBP, are these safe to buy, think it may have somthing to do with euro adpators?
Last edited by ALIEN1X; 06-06-2012 at 2:38 PM. Reason: More info added to question
Old 06-06-2012, 4:17 PM   #679
No it is just re-writing header information - no conversion of video/audio.
Old 07-06-2012, 10:31 AM   #680
KevG123's Avatar
Yes
Recommended to put NMT Apps on a usb stick
Old 27-06-2012, 11:32 PM   #681
destre's Avatar
Thanks: Gave 5, Got 0
Does the autoframerate work well ?
Can i choose to set up 23,976 fps with MKV ?
Old 28-06-2012, 12:13 AM   #682
Rom Rom is offline
Yes, simply set framerate in the settings to what your TV supports. Usually (in Europe) set it to PAL/NTSC/24P and it will auto switch.
Don't leave the Video output on auto, set it to what your TVis natively, eg 1080P50. Auto is just for a fallback mode, if left on Auto you may hit juddering on some videos.
Old 28-06-2012, 9:07 PM   #683
Rom Rom is offline
Updated: NMJ Toolbox | The Original Windows Editor for the Popcorn Hour NMJ!
1.0.3.0
Changes:
Added Playlist processing tab
Added view/add/edit/delete NMJ Based playlists
Added facility to add/remove one or more tracks in an existing playlist.
Added view/delete file Based playlists (eg m3u etc)
Added verification of tracks in playlist, if track is not in DB (NMJ Playlists) or references a track that does not exist (file based playlists) then the track entry will be highlighted in red.
Added auto check for discrepancies when viewing playlists. Will correct sequence and item count in NMJ based playlists.
Renaming a file based playlist in NMJToolbox will auto rename the actual file as well.
Fixed:
Removing a music track no longer deletes all playlists the track belongs to
Playlist sequence now re-numbered when a track is removed.
When searching TMDB and using API3.0 and multiple movies are returned dialog says 'Movie' rather than 'Series'.
Old 14-07-2012, 12:26 PM   #684
Rom Rom is offline
Updated, added photo processing. Now all sections are added you can let me know bugs or features that you would like me to address in the program so all suggestions are welcome!
1.0.4.0
Changes:
Added Photo & Album processing
Added selection of effects for photos including rotate, B&W and Sepia.
Allow save over original image or save as new entry in same album
Allow creating and renaming photo albums
Add, delete & remove photos on a photo album
Move photos between photo albums with drag & drop
Auto photo info grabbed from photos where available
Enabled Double click in Album & Track genre boxes to open edit window.
Change handling of saving files to remove colons from filenames as will cause windows save errors.
Fixed:
Stopped error being generated when changing tabs too quickly (changing whilst the previous tab's treeview is being processed)
Issue in some circumstances where image saved path saved to DB is incorrect.
Issue where in some circumstances a GDI+ error is generated when saving images (this is due to windows file locking, you may still get the error in some areas as I may not have caught them all so please report any you get).
Old 17-07-2012, 2:55 PM   #685
Tboggie's Avatar
Thanks: Gave 17, Got 111
Popcorn Hour A-300 firmware release:05-02-120711-23-POP-421-000 and NMT apps:05-02-111220-23-POP-421
Release date : 17 July 2012
Firmware version : 05-02-120711-23-POP-421-000
Known Issues
- BD switching audio track is still not stable
Firmware
- Added HLS support
- Added RTSP/MMS support
- Added UTF-16 subtitle support
- Added archive function on Kartina.tv and Polsky.tv Apps
- Fixed after FF mkv files, the subtitle and audio losses sync with the video.
- Fixed the subtitles height is relative to the video being displayed and not to the actual screen.
- Fixed UPNP Directory Listing repeats if UpdateID is incremented
- Fixed unable to go back to Home page when playback audio flash app by pressing Home/Source button RC
- Fixed unable show OSD on TV at 3D video playback
- Fixed cannot detect the FAT16/FAT32 USB thumb drive if plug in the USB thumb drive after player boot up
- Fixed cannot set media destination to internal Sata HDD if USB thumb drive is connected
- Fixed setup: fail to get wifi connection for this security "WPA2-personal ? WPA-TKIP/WPA2-AES" at Linksys Cisco Router
- Fixed cannot play the mkv with 23.976fps with framerate sync on at different TV mode
- Fixed cannot play the mkv with 29.97fps with framerate sync on at different TV mode
- Fixed cannot play the mkv with 25fps with framerate sync on at different TV mode
- Fixed after repeat playback the video, subtitle is unable to show
- Fixed sometime cannot resume next music track after add to queue
- Fixed WMP11 server: Playback "44hz-337kbps(vbr).wma" file will cause player hang
- Fixed "Add to queue" music feature doesn't show added tracks at now playing screen
- Fixed access to the wrong filter as video instead of photo
- Fixed WMP11: Get "could not open" message when single photo file playback
- Fixed fail to detect the internal sata HDD if USB thumb drive connected in some cases
- Fixed playback MP3 with PNG album art will crash the device
- Fixed Rwin always stay at 5290 (the value shown on screen will still be 5290, but we use Auto Mode now, so the value changes every time to best value)
- Fixed BD Navigation menu failed to launch if there is music playback at background
- Fixed did not have file view or prompt for BD navigation
- Fixed press TV mode button + 3 did not show any message on the screen
- Fixed no response when pressing Source/Home key at setup/apps market page during Audio-CD playback
- Fixed the Local Media show a red cross if have Audio-CD inside the DVD/BD-Rom
- Fixed Youtube got no audio output thru Spidif
- Fixed the info bar can not show up during Audio-CD playback
- Fixed need to reboot the player only able to detect the USB DVD/BD Rom
- Fixed other bugs
Home Screen
- Added Vietnam, Romanian, Croatian and Korean language
- Added remember last access feature
- Added allow to playback video or audio disc and direct access to drive directory if only one local drive.
- Fixed access from home screen, show NMJ icon at file browser when there is only one storage which is not NMJ
- Fixed after removing the database but still show J icon at HDD if press on source button from RC
NMJ 2.0
- Added a new category "Recent scanned"
- Added TV series episode list to support wrap around
- Enhanced Genre, Year, Rating, Artist menu to remember the last selected item
- Added Vietnam, Romanian, Croatian language
- Fixed UI issue casuing by "switch to file browser" from jukebox UI
- Fixed show wrong instruction/description on general category of Help
- Fixed Show black color cursor at screen keyboard when try to add a playlist at music details
- Fixed does not show storage icon after back from jukebox manager
- Fixed cannot do single playback from episodes button
- Fixed certain movie show 0sec or -44sec at movie main page from Just Scanned category
- Fixed UI showing "|" at movie detail page if only have one subtitle
- Fixed the tool tips at Episodes list option buttons misaligned in wall and list view mode
- Fixed after certain steps get empty thumbnail at Just Scanned category
- Fixed show "undefined" as movie filename at movie detail page thant happened on Just Scanned category in category view mode
- Fixed missing HDD icon at jukebox manager when switching from NMJ to jukebox manager
- Fixed wrong playlist number shown at info bar during photo slideshow at Just Scanned category
- Fixed the photo slideshow doesn't play in sequential order at Just Scanned category
- Fixed certain photo play in reverse order at "by album" in category view mode
- Fixed MP3 gapless files played in reverse order at "by album" issue
- Fixed switch to file browser prommpting error message if focus at path/file name with ampersand at NMJ
File Browser
- Added the ability to add song to queue
"Enter" will show a popup to add songs to queue or to play selected song immediately
- Added remember source sorting order
- Added support remember current focus after refresh when performing any file operations, changing filter or sorting order
- Added support next and prev navigation in Movie info page
- Added remember last setting for cap/numlock mode
- Added cap/numlock OSD display
- Added more option for search movie info result in Edit Movie page
- Added video and music thumbnail support for uPnP
- Added ability to remove network shared folder at Network Media listing
- Enhanced search input handling by immediately overwrite default text in input field upon first entry
- Added playback single photo upon Enter keypressed with option to navigate to other photos using Next/Prev keys or turn to slideshow using Play key
- Fixed Error 901 issue after completed Add Share from Setup
- Fixed video thumbnail not able to shown for the m2ts file
- Fixed the last wording from the actor column is partially cropped at Movie info page
- Fixed info/descending/mark/add share being shown in UI when try to browse via Network Share in Setup
- Fixed unable close minibrowser when frist user storage does not contain any folder
- Fixed incorrect SRT being download issue
- Fixed unable to perform "All" filter at the first level folder either from SATA/USB device
- Changed "Kb" to "KB" in file listing
Setup
- Added Vietnam, Romanian, Korean and Croatian language
- Added mandatory marker * at Share name field in edit share page
- Fixed unable to remove share record in edit share page when share name field is empty.
- Fixed unable to update setup lock status upon setup lock action
- Fixed error code 52 issue when same record being input in Device Name, Sambe Workgroup field
- Fixed UI freeze issue in Other network page after selecting the Wifi security
- Fixed the share name being overwritten after after editing
- Fixed add share protocol status being reset to default issue
- Fixed UI freeze issue while toggle or press Left key to select add share protocol
- Fixed Home screen showing empty items when setting system language to Portuguese
Setup Wizard
- Fixed Configuration Proxy Server page at Setup Wizard not in-sync with Setup page issue
- Fixed unable to prompt the password popup box after change the security/password from same SSID
- Fixed Unable to launch Setup Wizard from Home page and App Market
Apps Market
- Added Mature Content Feature to AppsMarket
- Added Romanian and Vietnamese language.
- Updated AppsMarket launching flow.
- Added TuneIn and TWiT (Live) Apps
Old 21-07-2012, 7:29 PM   #686
Rom Rom is offline
New update NMJ Toolbox | The Original Windows Editor for the Popcorn Hour NMJ!
Changes:
Added extra checks in the ‘Checks for Orphans’ option on the utilities menu
Adding a new movie now adds a default set of images for that movie (if found on TheMovieDB) – You can still change after the movie is added though.
Added tooltip to mediainfo button
Added mediainfo enabled to existing photo entries to re-query the image.
Fixed:
Display problem on Released Date on TV Series & Seasons. Changing appeared not to update.
Fixed issue when selecting renumber episodes and video count on utilities where the last movie in the DB is changed to a TV series.
Fixed image width & height on photos – was using exif image dimensions which were 4x the actual image sizes.
Fixed issue detecting series season and episode numbers when the file has no ‘.’ in the name
Fixed more circumstances where a GDI+ error is generated when windows lock image files.
Corrected number of episodes attached to a season when moving a multi file ‘movie’ to a tv show.
Old 22-07-2012, 10:23 PM   #687
Rom Rom is offline
1.0.4.2
Changes:
Added checks for startup position being out of the screen resolution bounds. If so, the window will start in the top left corner.
Added facility to auto fix albums where the NMJ scanner places every track in its own album (incorrectly, usually FLAC files). See below for details.
Fixed:
When adding a TV show that has multiple results and some of them have never been aired, the details returned sometimes are for a different show.
Note: I have added the facility to the right click menu of the album. It will only do one disc at a time. It will group ALL tracks that have the same album title and reside in the sme folder as the tracks in the album that you right click on. I did it this way so that multi CD albums would only group the tracks in the same disc folder.
EG.
I have the Ministry of sound which is a 3 CD album and my folders are like this:
Ministry of sound 80s
...CD1
.......Track 1
.......Track 2
.......Track 3 etc..
...CD2
.......Track 1
.......Track 2
...CD3
.......Track 1
.......Track 2
So if I right click on the album for CD2 it will only group the tracks that are n the CD2 folder that are not already in the album that is right clicked.
Old 24-07-2012, 4:52 PM   #688
Thanks: Gave 22, Got 19
Thanks to Rom for this excellent piece of software and regular updates to make a great piece of software even better!
Would be lost with out NMJ toolbox and Rom's assistance.
Dont forget to make a donation if you use rom's NMJ toolbox, hes a great guy !
Rom (25-07-2012)
Old 25-07-2012, 11:08 PM   #689
Rom Rom is offline
Update to correct the couple of bugs that BigKid & Vaughan identified.
1.0.4.3 - 25/07/2012
Changes:
Added auto fix for issue with nfs share paths below
Automatically create missing alphabetical indices if missing
Fixed:
Using nfs paths changed the : to _ when adding new files.
When updating an incorrect movie entry using the 'TMDB' button the index was not updated on the new title.
When adding a title to the index and the letter does not have an entry the title is put in the previous initial's index
Old 26-07-2012, 7:26 PM   #690
Rom Rom is offline
http://nmjtoolbox.net
Quick Update
1.0.4.4 - 26/07/2012
Changes:
Given focus to select button when multiple movies box is shown whilst adding a movie.
Given focus to OK button when adding a movie and title is being confirmed.
Fixed:
Error generated when adding new files with an apostrophe in the title (introduced in last release)
