Popcorn a300
Old 13-02-2012, 11:33 AM   #361
Dan201's Avatar
Thanks: Gave 364, Got 117
I just read this is a review;
The A-300 runs its own jukebox software to index your files and attach images, but it will only work on files stored locally. Once the process is done, however, it makes finding and browsing your movies far more enjoyable.
Is it true that the jukebox only works on local media and not networked media?
Old 13-02-2012, 11:35 AM   #362
KevG123's Avatar
Thanks: Gave 31, Got 47
Not true - works with networked media
Dan201 (13-02-2012)
Old 13-02-2012, 11:36 AM   #363
Dan201's Avatar
Thanks. I couldn't see why it wouldn't but wanted to make sure.
Old 13-02-2012, 12:21 PM   #364
Thanks: Gave 129, Got 112
Any reason why 96k/24 bit multi channel flacc files won't play?
OK if in wav format.
Old 13-02-2012, 1:44 PM   #365
KevG123's Avatar
There are a few niggles with trying to edit individual film poster/fanart via NMJ for network shares, but this is a well known problem that will hopefully be addressed in next fw update.
As long as your movies are named ok then NMJ will find most of them.
For the ones it doesn’t find, there is ROMs NMJToolbox
Old 13-02-2012, 1:50 PM   #366
Dan201's Avatar
I think ill hold off for now then. Ive got a dune max at the moment which I like but im looking for a device that can simply read my network share and find info for it without any input from me. Once the niggles etc have been sorted out ill have a rethink.
Old 13-02-2012, 1:55 PM   #367
ROMs NMJToolbox is essential for maintaining your NMJ. However, it doesn't suppor tmusic (yet), for which I use the NMJED Windows editor.
Been using both all weekend!
Old 13-02-2012, 1:57 PM   #368
KevG123's Avatar
Thing is Dan its really not a major problem
When I ran NMJ for the first time for a network share, it found about 90% of my movies
For the other 10% you just fire up Rom’s NMJToolbox on your pc, point it to the share and browse thru the list of movies. When you see a blank poster/fanart, just add the poster etc from the choice given by the NMJToolbox.
Old 13-02-2012, 8:22 PM   #369
dunks517's Avatar
Thanks: Gave 520, Got 498
Originally Posted by Rom
If you are using a NAS you don't *need* any internal storage. However, if you want it then you can have 2.5, 3.5 drive or a USB pen drive. Entirely up to you.
USB cheap & silent but small capacity & sticks out of the player.
3.5" cheaper than 2.5", larger capacity per £, noisier & hotter.
2.5 most expensive but larger capacity than USB and quieter/cooler than 3.5"
You only need an internal drive if:
You want to store things locally on the PCH
You want to be able to access the internal drive from a PC
You want to use the built in News/Usenet client
You want to install community written programs & utilities
You want to use BD menus/bookmarks (it needs a 4gb partition for the BD 'persistant storage' standard)
Any news on the new NMJ for the a-210 yet?
Old 13-02-2012, 8:37 PM   #370
Rom Rom is offline
Restricted Member
Thanks: Gave 41, Got 736
No, apparently there is a firmware that is in QA at the moment and we are waiting for Syabas to decide on whether to unleash it on the beta testers. This is for the C-200 and if/when released to joe public an A200/210 one usually follows a week later. However, it has also been stated that this firmware does not include NMJv2.
Old 13-02-2012, 8:41 PM   #371
saguk1234's Avatar
Thanks: Gave 115, Got 121
Wouldnt it be easier to use Eversion than nmj?? It's easy to use and setup.
Old 13-02-2012, 8:41 PM   #372
dunks517's Avatar
I'm not too bothered about NMJ, I just want all my media in one library just like My Movies and without requiring a degree in networking. The WAF doesn't stretch as far as several libraries. The PCH is a potentially great product let down by poor implementation.
Old 13-02-2012, 9:11 PM   #373
Rom Rom is offline
Restricted Member
Then YAMJ + Eversion is your answer. Eversion allows dynamic mounting of shares so you can have media from different sources in one library. It is also flash based so you have dynamic popups etc.
Its actually what I use
Old 13-02-2012, 9:30 PM   #374
dunks517's Avatar
Old 15-02-2012, 7:40 AM   #375
Ryan233's Avatar
Thanks: Gave 2, Got 23
I'm gutted this morning, received a email from pix mania when saying there are awaiting stock of the A-300 . Possible delivery date is now the 23rd march. Which Is not good enough so I have just cancelled my order.
Old 15-02-2012, 7:48 AM   #376
Umster's Avatar
Thanks: Gave 17, Got 6
I got email to say my unit has been dispatched. Is pixmania the only place to purchase them from at a good price??
Old 15-02-2012, 7:51 AM   #377
Ryan233's Avatar
Pix mania or direct from popcorn hour. I'm absolutely gutted about the stock levels of pix mania, firstly there said there would dispatch on the 15th, which it would have been today but now it's going to a estimated delivery of 23rd march.
Old 15-02-2012, 8:28 AM   #378
Umster's Avatar
Just checked website states 17th as stock to arrive
Old 15-02-2012, 8:32 AM   #379
Ryan233's Avatar
Yeah I have just seen that, I'm going to give them a call to see what's going on.
Old 15-02-2012, 9:20 AM   #380
KevG123's Avatar
Found some here
Originally they were a mad price but this looks ok
Popcornhour A-300 NMT Mediaplayer w/o harddisk: Amazon.co.uk: Electronics
Old 15-02-2012, 4:08 PM   #381
Umster's Avatar
Smile
Originally Posted by KevG123 View Post
Found some here
Selling @ £229.99 a bit more than pixmania. shame Amazon.co.UK are not selling them
Old 16-02-2012, 9:29 AM   #382
Umster's Avatar
Got my unit from pixmania, however the power lead is European round 2 pin. They have sent me an adaptor however it is for a square European plug any one else had this issue
Old 16-02-2012, 9:33 AM   #383
saguk1234's Avatar
Just cut the 2 pin off and attach the uk plug to it.
Old 16-02-2012, 9:41 AM   #384
Umster's Avatar
That is what I was going to do, but was worried that it would invalidate my warranty. Or even just to change the lead to UK kettle lead
Old 16-02-2012, 1:05 PM   #385
KevG123's Avatar
I just used a UK kettle lead - surprised how many I had in the garage
Old 16-02-2012, 1:39 PM   #386
Umster's Avatar
They should still be send out the correct adaptor with the unit as some people don't have these cables at hand. This could infact be an additional cost to them. I have sent them an email outlining this
Old 16-02-2012, 4:17 PM   #387
Thanks: Gave 22, Got 20
I was one of those persons !
A300 arrived, inboxed it and discovered the adapter wouldnt fit the plug.
I had a clear out months ago of leads i dont use.
Had to jump in car and drive to maplins who had the correct adapter.
I emailed pixmania and told them about this, and that i wanted a refund for the incorrect adapter.
emailed the receipt and a refund was in my bank after a few days.
Old 16-02-2012, 5:28 PM   #388
Umster's Avatar
That's a good way of doing it, So far we have purchase 4 units from them, each time the adaptor has been incorrect.
I have emailed them to advise them of this and also sent them a link to the correct adaptor on there website and still they keep on sending me the incorrect adaptor.
I wonder how many more people have this issue??
Old 16-02-2012, 11:59 PM   #389
Rom Rom is offline
Restricted Member
New release available: NMJ Toolbox | The Original Editor for The PopcornHour NMJ!
1.0.1.6 - 16/02/12
Added a SQL dump routine for debugging when a SQL update fails (will be saved in the NMJToolbox application folder called debug.txt).
Added when adding additional episodes to a TV series, theTVDB is automatically queried.
Added a few tweaks to the date routines.
Added checks for when theTVDB is queried with an IMDB 'tt' ID and the series returns no results (with added help message).
Stopped showing an error message when bulk updating the IMDB ratings but the title has no rating.
Fixed SQL error where adding an ISO of a tvshow with multiple episodes and MediaInfo does not retrieve a run time.
Fixed the add movie/TV file browse dialog not showing ISO files.
Fixed adding a new TV series/episode potentially using a different TTID to query the TVDB - which gave incorrect results.
Fixed not being able to remove a genre when the NMJ creates one that starts with a leading space.
Fixed error generated in some cases when a 'ttid' is not completed when adding a new TV show.
Fixed the 'Query TVDB toolbar being enabled (and causing an error when clicked) when initially opening NMJToolbox2 and on the movies tab.
Old 17-02-2012, 8:14 AM   #390
Thanks: Gave 43, Got 25
Hi, I am looking to buy an A-300 and would like some guidance if possible please before pushing the button.
After reading the thread I am happy the Popcorn Jukebox will work with my Synology Nas even though reviews state otherwise.
At present I have 2 Mede8ers using YAMJ 2 Mede8er to create the jukebox for my movies.
Can I continue to use this side by side with the jukebox for the Popcorn Hour A-300?
I am hoping the Popcorn Jukebox will create a seperate file on my NAS and work along side the Mede8er Jukebox .
Regards mipmip.
