The new Blu-Ray/HD-DVD/DVD Ripping Guide for Media Streamers
Thread Closed
Old 08-09-2010, 9:30 AM   #181
Thanks: Gave 71, Got 77
Guys if you can give me some ideas about the below it would be really appreciated.
Im now using tsmuxer for majority of discs and its working well, however I have a few multi-part discs (Toy Story & 2)which as suggested earlier you have to use clown bd for.
Both my discs are brand new, and in immacculate condition and play without any issue at all on any br player - however TS 2 ripped correctly without any issue , but Clown bd insists (on 3 diff attempts) that "disc integrity is faulty" and wont proceed for original TS disc
I could try and blag HMV into swapping the disc like for like, but I dont actually have the receipt so its unlikely thats going ot work (and afterall it does play ok)
Any ideas?
Old 09-09-2010, 9:45 PM   #182
Illustrious Member
Smurfin's Avatar
Thanks: Gave 793, Got 1,227
Any ideas?
Toy Story 1 and 2 worked fine for me. Probably a dodgy disc (ripping software seems to be quite sensitive in my experience). Try running it through ToNMT, then if it works just re-run it through tsmuxer to make it into a Blu-Ray folder. ClownBD isn't the only way to rip multi-part discs
HugoFJH (21-12-2010)
Old 15-09-2010, 4:20 PM   #183
Bossk128's Avatar
Thanks: Gave 61, Got 73
This may seem like a lazy question, but I've looked and can't find a simple answer. My powerline network can only stream at 2.5mb/s (or 20Mb/s) - what can I add to High Profile in advanced to state this as a max bitrate (combined audio and video of course!).
Cheers.
Old 23-09-2010, 7:08 PM   #184
point zero's Avatar
Thanks: Gave 38, Got 34
Been ripping my bluray collection for a while with no real issues untill now, i just ripped "Kick Ass" the problem im getting is it plays everything through my side speakers and nothing through my centre speaker.
I am using the latest version of AnyDVD (6.6.9.0) and using ToNmt to rip it in a .ts file, i have been doing this with all my blurays and it hasnt been an issue un till now, i also ripped "Shelter" and its the same problem but then i ripped "universal soldier regeneration" and its fine.
Any suggestions??
Old 23-09-2010, 7:49 PM   #185
Illustrious Member
Smurfin's Avatar
Originally Posted by point zero View Post
Any suggestions??
Download a copy of media info and get it to check the file - this should show you what audio is encoded on the rip.
Is Kick Ass a multi-file or single file BD? If it's single file, also try ripping it with just tsmuxer and see if that cures it.
Old 23-09-2010, 7:50 PM   #186
Illustrious Member
Smurfin's Avatar
This has reminded me - I've not updated this thread since the first post (sorry). I will try and get round to it with other ripping methods for different types of media in the next few weeks
Old 24-09-2010, 10:06 AM   #187
Thanks: Gave 62, Got 57
Any suggestions??
Try ClownBD. It's more longwinded than ToNMT but you get to see which audio tracks are being selected.
Old 24-09-2010, 11:17 AM   #188
Illustrious Member
Smurfin's Avatar
You can with tsmuxer too
Old 24-09-2010, 4:10 PM   #189
Eminent Member
Thanks: Gave 477, Got 2,051
I use clownbd and had no problems.
I used to use tsmuxer on it's own but it doesn't work with seamless branching titles (such as Pixar and Disney). Audio can also be out of sync. As Clownbd uses Eac3to to extract, it uses the audio delay. Audio often starts a several ms after the video. It also handles the seamless branching.
Old 24-09-2010, 4:12 PM   #190
Illustrious Member
Smurfin's Avatar
That's why i asked if it's single file. If it is there's no issue with audio delay either
Old 24-09-2010, 4:24 PM   #191
Eminent Member
I have had out of sync with single files too which I will always use the ClownBD GUI.
The audio will go out of sync when each seamless branching title starts and gets worse as it goes.
Old 24-09-2010, 4:29 PM   #192
Illustrious Member
Smurfin's Avatar
Not been an issue that I've found I must say, tsmuxer is fast and perfect for single file.
I know
Old 27-09-2010, 7:50 PM   #193
Assured Advertiser
MeanDorris's Avatar
Thanks: Gave 323, Got 319
Any suggestions??
Not really too sure why people are messing with ToNMT, TSMuxer or ClownBD just to rip blu rays to m2ts or ts files?
How much space to do really save compared to just browsing the disc and copying the largest m2ts file (on non branching titles at least)? Sure you could strip out the foreign language tracks but is it really worth the messing in the grand scheme of things?
Buyonline : www.avaficionado.co.uk | dean@avaficionado.co.uk | 0845 370 0054 | AVaficionado
AV Aficionado supports AV Forums as an Assured Advertiser, please consider supporting us back.
OPPO BDP-103EU & BDP-105EU MultiRegion & MultiZone/Region : JVC X Series Projectors
Old 27-09-2010, 8:15 PM   #194
Eminent Member
I am using ClownBD to create movie only Blu Ray ISO's not m2ts or ts files. The iso can then be burned to a disc or played on a media streamer (with chapters intact).
Old 28-09-2010, 6:47 PM   #195
Illustrious Member
Smurfin's Avatar
Every GB counts imho, although in my case it's more to do with that I want proper BD structures - m2ts files are too limiting in my experience, though you're right...nothing inherently wrong with just copying the largest file across (for single file movies).
Old 28-09-2010, 8:11 PM   #196
Eminent Member
The removal of a LPCM track can be as much as 6GB saving. Many THD or DTS-HD MA audio are still several GB in size.
Old 29-09-2010, 7:52 PM   #197
Assured Advertiser
MeanDorris's Avatar
OK, but if you have gone down the BD route why remove the hi-res audio tracks? Unless there are also some foreign language ones but this seems rare...
Old 29-09-2010, 8:00 PM   #198
Illustrious Member
Smurfin's Avatar
You wouldn't, just if there are duplicates which there sometimes are.
Old 29-09-2010, 8:22 PM   #199
Eminent Member
Not everyone one like myself can use HD audio so no point in saving it. Also, not all media streamers can actually handle HD audio.
Old 03-10-2010, 3:02 PM   #200
Thanks: Gave 2, Got 4
What do people want to see next? Your choice is the following:
DVD ripping guide
HD-DVD conversion to Blu-Ray
HD-DVD TV series ripping
Ripping both Blu-Ray/HD-DVD for the PCH C-200.
Here is one vote for HD-DVD series ripping.
Finally got Tonmt working. Windows 7 clearly have different locations for Eac3to and Java and there is no path to them. Thus paths must be added to get it to even run. I wonder if anyone else came across this and gave up. I almost did.
Most of my HD-DVDs are ripping away happily and playing back on Dune HD Max very happily. No luck in getting other than first episode of TV series so far, even making manual selection.
Ian
Old 03-10-2010, 3:07 PM   #201
Audio overlap on Luck # Slevin HD-DVD
I received a message on Tonmt saying I had an audio overlap of 330ms at time=0.00. Sure enough the audio track is 330ms out all the way through. This is such a great movie I would like to fix this. m2ts format and I just have audio passthrough.
Many thanks,
Ian
Old 03-10-2010, 3:37 PM   #202
Eminent Member
Many thanks,
Ian
You can enter the audio delay in Tsmuxer.
lumos (03-10-2010)
Old 03-10-2010, 6:39 PM   #203
Is that possible when it is being called from Tonmt? I could not see any parameters that it exposed in Preferences.
Thanks for your reply,
Ian
Old 03-10-2010, 8:31 PM   #204
Eminent Member
Ian
I don't know. I use clownbd or tsmuxer with its gui. With that gui, it is possible to enter the delay.
SmartLabs - SmartLabs tsMuxeR
Old 03-10-2010, 9:12 PM   #205
I have solved the problem. I did not use autosource the second time but manually chose the two feature EVO files. This encoding presented three EVOs when using autosource and it seems that the first one screwed up the features.
Perfect sync now as with every other HD-DVD rip.
Now to work out what I am going to do with all my HD-DVD TV series.
Thanks for your help,
Ian
Old 03-10-2010, 9:31 PM   #206
Eminent Member
clownbd will convert HD-DVD to BD/m2ts/ts. You can select each episode and create individual files.
Old 04-10-2010, 2:39 PM   #207
Thanks: Gave 199, Got 377
Ian
If you haven't tried it (recently) then MakeMKV is now better supported for HD-DVD. I tried Battlestar Galactica the other day and it seemed to work fine (although my aged A110 won't pass-through HD audio on MKV files...)
Old 04-10-2010, 2:45 PM   #208
Thanks, I will add it on my list of things to try. I noticed that the Tonmt speed dropped to 7MB/s on the last conversion. I checked my 16TB Drobopro and sure enough it was showing a disc failure. A credit to the DroboPro, I took out the dead WD EARS 2TB, popped in a new one and saw the speed increase to 18MB/s. That is not bad considering it was reading an ISO from the Drobo and writing the M2TS back to it whilst rebuilding its array. It never missed a beat.
Thanks for your help; I think I will pause my ripping to give the Array time to rebuild.
Ian
Old 06-10-2010, 11:26 AM   #209
Thanks: Gave 7, Got 2
Hi all, I am using anydvd and DVDShrink, just backing up main film to IFO/VOBs I am using 1Gb file size as recommended by DVDShrink, but during playback I get a black screen for a fraction of a second between each file, to make matters worse when playing them on my WDTV live it changes audio source to directors commentary when changing to next file in sequence, I don’t really want to compress all my DVDs to mkv or mpeg4 (still considering this for my PS3 though)
Should I just create 1 large VOB?
Should I compress them?
Or is it a settings thing?
Kieran
Old 06-10-2010, 12:44 PM   #210
Eminent Member
In Shrink just use reauthor mode and make iso's. The WDTV will play them. You can also select only the audio you want.
You can still compress them or leave it at 100% quality.
Thread Closed
