Originally Posted by Fe_man2000 Something is wrong - 1080p over wired works perfectly on the A110. 100mb ethernet is around double the speed needed for full HD files - not sure I can tell you what it is on your setup but I can tell you to keep trying. |
Can I take it that you've managed to stream full 1080p via a wired Ethernet connection?
Do you use SMB or NFS?
I originally used SMB, but when I got my NAS and heard that it was better to use NFS for HD streaming, then I switched to NFS. I assume if I did not use the correct NFS setup parameters on the A110 I would not get anything. So, I can only assume that I have correctly setup NFS.
Perhaps I should revert to SMB and give that a try?
Can't think what else I could've done wrong.
Any firther suggestions or ideas would be appreciated.
