| need some help using tsmuxer
ill got the program to work as it should,but only on files that are under 8.5gb after they have bin true the program.
and i dont want to have bluray movies bigger than 8.5gb. i use dual layer disk.
and as we know this program turns the g.b up from when you start it around 0.5 gb and a bit more on a file.
and i have meny mkv files. downloaded. but they are either over 8,5 gb in the first place,ore around 8gb, and then they will also be to big after using the program to be burned out.
so how can i get the mkv files that are around 7gb before i use them in the program smaller before i use it in the program? seem like 7gb is good.
