| Re: Wifi HD Media Player recommendations
My TV is only 720P so the 54g wifi I hope should be enough f͘or the moment. I would be using HDMI (plus 2xRCA for audio if necessary).
I can't wire both the PC with the files on it and the media player to the router, so I am using a wired connection from PC to router and wifi to the media player.
Getting a wifi adapter to go with some of the players I have looked at is difficult. Someone suggested the Sumvision Cyclone player but I found it near impossible to find a compatible wifi adapter for it.
Also firmware support going forward is important, some of the cheaper models might not get any firmware updates.
Fangio.
