I have a bit of a strange and frustrating problem with my WDTV Live.
When a USB storage device is inserted it plays every video file i throw at it without a hitch.
However when streamed over the Network, it has somehow gone bad.
I am using a Belkin N1 Vision Router, the connection is Wired, the PC in use as a Media server is running Vista Ultimate x86, and TVersity. (PS3 Media Server hangs after a while of use with WDTV Live for me)
The only problems i have with Network Streaming are with .MKV files. The video plays perfectly, but it states on screen that there is No Audio Channel, yet it can play it locally through USB.
How would i go about fixing this?
Here are some details from Mediainfo on the .MKV files that won't stream properly over the net.
#1:
Code:
Format : Matroska
File size : 7.53 GiB
Duration : 1h 45mn
Overall bit rate : 10.2 Mbps
Encoded date : UTC 2009-06-25 08:12:20
Writing application : mkvmerge v2.9.5 ('Tu es le seul') built on Jun 7 2009 11:19:30
Writing library : libebml v0.7.8 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 45mn
Bit rate : 9 404 Kbps
Nominal bit rate : 9 608 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.189
Stream size : 6.90 GiB (92%)
Title : Ghostbusters
Writing library : x264 core 67 r1162M f7bfcfa
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=9 / psy_rd=1,0:0,0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=9608 / ratetol=1,0 / qcomp=0,60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20,0 / qblur=0,5 / vbv_maxrate=38000 / vbv_bufsize=30000 / ip_ratio=1,40 / pb_ratio=1,30 / aq=1:1,00
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 45mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 481 MiB (6%)
Language : English #2
Code:
Format : Matroska
File size : 1.09 GiB
Duration : 41mn 24s
Overall bit rate : 3 776 Kbps
Encoded date : UTC 2008-12-16 03:19:49
Writing application : mkvmerge v2.4.0 ('Fumbling Towards Ecstasy') built on Nov 7 2008 17:24:23
Video
Format : AVC
Format profile : High@L3.1
Format settings, ReFrames : 4 frames
Muxing mode : Container profile=Unknown@3.1
Duration : 41mn 22s
Bit rate : 3 317 Kbps
Nominal bit rate : 3 390 Kbps
Width : 1 280 pixels
Height : 720 pixels
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.150
Stream size : 982 MiB (88%)
Writing library : x264 core 64 r987 e71168d
Encoding settings : cabac=1 / ref=4 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=hex / subme=6 / psy_rd=1.0:0.0 / brdo=1 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=3390 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 41mn 24s
Bit rate : 384 Kbps
Stream size : 114 MiB (10%) This .MKV file works from streaming over the network:
#1
Code:
Format : BDAV
Format/Info : Blu-ray Video
File size : 4.63 GiB
Duration : 1h 30mn
Overall bit rate : 7 313 Kbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : Main@L4.1
Duration : 1h 30mn
Bit rate : 6 374 Kbps
Nominal bit rate : 6 261 Kbps
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.128
Stream size : 4.04 GiB (87%)
Writing library : x264 core 61 r949M 60c4f7e
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=6 / psy_rd=1.0:1.0 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=10,6 / chroma_qp_offset=-4 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=6261 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.0
Audio
Menu ID : 1 (0x1)
Format : AC-3
Duration : 1h 30mn
Bit rate : 640 Kbps
Stream size : 415 MiB (9%)
Any help please? Seriously don't know what to do, or where to start
Thanks!
