Originally Posted by ukchevy Should I update the firmware before doing anything else, if so to what version? |
Newer versions of the firmware will be more stable so it makes sense to make sure it's up to date before starting. It may save some headaches.
Check on NMT forums where the most current firmware is linked on the front page.
Originally Posted by ukchevy I hear it's best to reformat the drive and not to use NTFS, not sure why. |
All the popcorn hours are basically Linux devices which natively use the EXT3 format for hard drives and not the windows NTFS format.
My understanding is that the C200 can read an NTFS disc but can't write to them.
Originally Posted by ukchevy Should I download any software? |
It depends what you want to do. For basic usage you don't need to download anything. You can get away with using just network shares, USB devices and/or a locally installed hard drive.
If you want fancy front ends like JAMJ or UMC and/or want to use the PCH for downloading torrents etc. then you will need to start installing software either on the PCH, your PC/NAS or both.
