Originally Posted by petrolheed My htpc setup does not agree with the wife, so i`m thinking along the lines of a network media player. My current NAS is not very good so I was considering a media player/nas all in one, last time I looked at these and there were only a couple on the market and they werent very good, but now theres millions of the things out there and I don`t know where to start.
I`m after :
NAS
Built in bittorent client
easy to use for the missus
must be fairly cheap.
If there are any out there that can view iplayer that would be handy too.
Any suggestions, or any sites where I can narrow down my choices? The info on here is good but quite hard to compare between different one.
Cheers. |
You could try XBMC or Boxee on something like an Acer Revo (i.e Atom ION) running Linux?
Your requirements:
NAS
Folders, Hard drive can be shared and USB HDD can be added to increase the size of the HDD
Boxee has a bittorrent client built in:
Boxee - Wikipedia, the free encyclopedia
or as its Linux and a full PC you could run uTorrent and set it up to download at night so the PC isnt tied up, the PC only uses 20-30W so its not going to cost you all that much
Do you have an iPhone or an ipod touch? If so, use this:
XBMC iPhone Remote
or this
Boxee Blog » boxee iPhone remote app available on the App Store
Otherwise get an IR remote, XBMC and Boxee have the advantage of being a lot easier and intuative to use and modify than most NMT players like the Popcorn Hour
The cheapest revo can be had for £150, or get the dual core version (for a bit more grunt) for under £170 delivered here:
Acer Revo 3600 Atom 330 Dual Core 1gb 160gb Linux Shop UK : Ballicom.co.uk : Buy Acer Revo 3600 Atom 330 Dual Core 1gb... If there are any out there that can view iplayer that would be handy too.
Boxee has an iPlayer viewer built in and XBMC can have one added by Plugin, tho note that the Revo does struggle a bit with flash playback as its all CPU based and not accelerated by the GPU, tho the next version of flash due out n Q1 2010 will fix this issue
http://www.avforums.com/forums/home-...rs-thread.html
