Go Back   AVForums.com > Home Entertainment Players and Recorders > Streamers and Network Media Players
Latest AVForums Movie Reviews
Music Man, The Blu-ray ReviewUgly Truth, The Blu-ray ReviewEmpire Of The Ants - Original Motion Picture Soundtrack CD ReviewThe Toolbox Murders Blu-ray ReviewDungeons & Dragons: Wrath of the Dragon God Blu-ray Review
The Book of Eli - Original Motion Picture Soundtrack CD ReviewInvention of Lying, The Blu-ray ReviewSmokin' Aces 2: Assassins' Ball Blu-ray ReviewDorian Gray Blu-ray ReviewL'armée du crime Blu-ray Review
Old 03-10-2009, 1:51 PM   #1 (permalink)
Thanks: Gave 19, Got 25
Pch/nas/yamj
Hello all,
I now have a popcorn hour a-110, a qnap 209 nas (2x1tb) and a 200mbps homeplug set up. The plan is to rip all my dvds and music to the nas and then either access it on the computer upstairs or via the tv and pch downstairs.
Some people have suggested using YAMJ for the pch, i read that this could be installed on the Nas so that my computer doesnt have to be turned on and also that if this approach is taken then ISO and vobs cannot be played. Is this still the case?
thanks
blasted is offline   Reply With Quote
Old 03-10-2009, 2:06 PM   #2 (permalink)
Thanks: Gave 164, Got 831
Re: Pch/nas/yamj
I think your getting a few things mixed up.
Myihome is a http streaming utility that doesn't support ISO's and video_ts folder structures. Yamj can be installed as part of myihome, but can also be used separately.
Yamj is not really installed, you run a utility on your PC which scans your media locations to produce a index and jukebox folder. This index file and jukebox folder can then be copied to your NAS, so your PC is only required for the scan. Once the scan is complete you just access the index file on your nas from the PCH to get the movie index with posters and details etc.
So you can use yamj with a NAS and your PCH.
My opinions expressed here do not represent those of the AV Forums or its associated websites
dwhite is offline   Reply With Quote
blasted (03-10-2009)
Old 03-10-2009, 2:39 PM   #3 (permalink)
Re: Pch/nas/yamj
ahh,
so i need to get both myihome and yamj on my pc, scan my nas for all the films and music, then copy the index back over to the nas. then just access that via the pch?
Old 03-10-2009, 3:01 PM   #4 (permalink)
Re: Pch/nas/yamj
No you don't necessarily need myihome. Thats just popcorn hour's own software for easy access, but it can be limiting, I would just use yamj on its own.
How is your nas connected to your PCH, by a network share?
You want to download the latest version of yamj and if your using a windows machine the yamj gui tool, to make it easier to setup your scan locations.
There is a dummys guide to setup also, but sometimes it isn't always the appropriate way to set it up as the guide says, as thats for multiple network shares. You will probably not need to do all the winbolic stuff, as I assume you will only have one network share to your NAS.
Old 03-10-2009, 4:47 PM   #5 (permalink)
Re: Pch/nas/yamj
right,
My nas is connected to a router which is then connected to a homeplug, then downstairs the pch is connected to the other homeplug. my internet and pc also connect to the router. I have been streaming films, so i know i have that bit set up right.
So then, I get the latest version of YAMJ and the GUI (on my pc) and point it at the film folder on my nas. this then builds a file which i copy back to the nas (assuming this has to be redone each time i add to my library). Reading through a few guides it talks about naming conventions, i have redone the x264 films on there but not sure on naming a dvdrip as an iso, is it name, year, type and format eg. "The.Devil's.Rejects.2005.DVDRIP.ISO"?
In the meantime I'm in the process of backing up my dvd collection. i have been doing this buy ripping with dvdfab, then converting to an iso using imgburn. I would like to remove some of the extras can this be done in dvdfab, or do i need to use dvd shrink?
Lastly i have copied a working iso across to my nas, the pch doesnt even see it, is this right?
many thanks for your assistance.
lastly i ha
Old 03-10-2009, 4:56 PM   #6 (permalink)
Re: Pch/nas/yamj
Naming convention looks ok for isos.
With the yamj GUI you can actually set it to store the jukebox on the nas directly, save you copying it.
Are you using myihome or not? With the ISO not showing, I suspect you are. You want to create a network share pointing at the NAS on the PCH instead.
Not sure about stripping things out, I just use AnyDVD and imgburn the entire disk.
Old 03-10-2009, 5:13 PM   #7 (permalink)
Re: Pch/nas/yamj
you were right, i just set up a share on the pch to point to the nas and the iso works, as an added bonus the flacs work which would have been my next question. a little dissapointed that you cant play a whole album in one go and jump from track to track, but one step at a time.
I shall have another go with the gui, it wrote a folder to the nas but didnt put anything inside of it. It looks like it wont scan.
pch or nas or yamj
Copyright © 2000-2010 M2N E. & O. E.
