08-07-2009, 11:12 PM
#1 (permalink)
Thanks: Gave 0, Got 23
nas box suggestions
im looking at buying a nas box, can anyone offer suggestions as to which one.
i would like it to have gigabit network connection and for the ps3 to be able to access it as well.
suggestions please
08-07-2009, 11:40 PM
#2 (permalink)
Assured Advertiser
Thanks: Gave 8, Got 95
Re: nas box suggestions
I suggest a netgear or a QNAP, worth checking out the QNAP's they released v3 firmware today.
09-07-2009, 8:30 AM
#3 (permalink)
Thanks: Gave 43, Got 52
I can report back very positively about my ReadyNAS Duo. Which streams easily via the PS3.
Open your eyes..... See what is there to be seen..... Do what needs to be done..... Make things happen.....
09-07-2009, 8:42 AM
#4 (permalink)
Thanks: Gave 1, Got 1
I recently purchased a Netgear Duo and it is streaming to my PS3 no problem at all.
Would definitely recommend it.
09-07-2009, 5:08 PM
#5 (permalink)
I've been using the Synology Disk Station, streams to my PS3/Xbox 360 with no issue. The Disk Station Manager GUI is awesome, makes my life and clients life easier to manage the box.
10-07-2009, 1:11 PM
#6 (permalink)
Thanks: Gave 12, Got 408
readynas here - if nothing else you get a 5 year warranty with 24 hour swap out, rather than a 1 year one
cheers, bogie
10-07-2009, 11:43 PM
#7 (permalink)
just been looking at readynas and it seems very impressive
11-07-2009, 6:32 PM
#8 (permalink)
tons of info on NETGEAR ReadyNAS Community
ive just upgraded to a Pro model
cheers, bogie
11-07-2009, 10:01 PM
#9 (permalink)
other think i would like to do is run the itunes server on the readynas and control it via the iphone, anyone attempted this
12-07-2009, 4:51 PM
#10 (permalink)
Thanks: Gave 15, Got 1
I wonder if any of you can recommend me a product for very specific requirements.
-Gigabit Ethernet
-4TB running in RAID1
-Support for the .mkv container (I have a lot of (legal) 720p HD content in this container, currently I'm having to use ps3mediaserver running on my PC to play these on my PS3, not an ideal solution)
-Support for Squeezebox duet
-Support for BitTorrent
12-07-2009, 5:05 PM
#11 (permalink)
sure you dont mean raid 0 fella
-Gigabit Ethernet
12-07-2009, 5:12 PM
#12 (permalink)
Nope. I want to mirror the data, RAID0 doesn't do that.
12-07-2009, 6:26 PM
#13 (permalink)
not quite, I do control my squeezeboxes using an Itouch though via a Readynas
cheers, bogie
12-07-2009, 6:27 PM
#14 (permalink)
-Gigabit Ethernet
well most NAS do that - you dont need them to support MKVs, thats for the client
out of the box, then a Readynas comes with Squeezecentre and bittorrent and works great
cheers, bogie
12-07-2009, 6:47 PM
#15 (permalink)
OK thanks for your reply, which ReadyNAS product would you recommend?
