AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Sounds Cards, Mics, Headsets and Computer Speakers
LinkBack Thread Tools Display Modes
Old 14-04-2008, 12:22 PM   #1 (permalink)
Thanks: Gave 51, Got 6
Auzentech Prelude. A question of DACs and unprocessed audio quality?
Hi All,
It's been a while!
I am considering the Auzentech Prelude 7.1 for my PC. I want to link my PC to my Yamaha Amp. However, I want all the processing done by the Yamaha amp as it is far more superior and has better DACs etc.
So, my question is, if I want to output raw unprocessed audio (not touched by the soundcard) while retaining as much quality as possible, which connectivity do I use to connect my PC to the Yamaha amp? It must be an analogue cable right? Like a phono jack? If I use Coaxial, it is digital right and so the soundcard will be processing the audio? Will I have better sound quality if I use an analogue cable from the PC to Amp and let the amp do the processing rather than have Coaxial from PC to Amp and have processing both ends?
Thanks all,
H
Get em Daddy is offline
Old 14-04-2008, 12:36 PM   #2 (permalink)
Thanks: Gave 1, Got 17
Re: Auzentech Prelude. A question of DACs and unprocessed audio quality?
you're correct in assuming that the analog conversion should rather be done in your receiver than inside your PC. you are, however, mistaken in thinking that the sound signal on the analog ports is unprocessed - the signal on the analog ports is usually identical to the signal on the digital ports - it's just converted to analog.
if you want your sound to be digitally and hence losslessly transported without any kind of processing, I suggest you take a look at my site - this can be easily achieved with a cheap trust 5250 / 5200 and my drivers.
http://code.google.com/p/cmediadrivers
dogbert is offline
Old 22-04-2008, 9:10 PM   #3 (permalink)
Thanks: Gave 12, Got 10
Originally Posted by Get em Daddy View Post
Hi All,
It's been a while!
Thanks all,
H
SUrely using the prelude as a pass through is a bit of an overkill ? A £20 generic card will do just as well if you are sending it via coax?
HT:Pio 506XDE, Denon 3806, KEF KHT 6000 x5, Velodne SPL 800, QED/Mark G cables.
GamePC: Q6600/8800GTX Dell XPS, Dell 2405 24 inch Monitor, Creative X-fi Gamer, HTPC: Origen X15 case, Intel E6300, 1Gb Ram, ATI 2600XT, 1.5Tb storage, Lynx 2b. Console: PS3
CrazyindianZA is online now
Old 08-05-2008, 2:55 AM   #4 (permalink)
Thanks: Gave 38, Got 178
what are you using it for?, if you want HD AUdio then you'd have to go with analogue outputs as it support 7.1 pcm, digital does not, granted you get a quality loss since DAC is happening, but it's the only way to get multichannel PCM audio, unless you get a new motherboard with HDMI and amp with HDMI then it will be all digital..., multichannel analogue out is the only way.., but get a dedicated soundcard like the prelude as it has better DAC's than onboard sound...
Erm...Yeah, I built a Mac
DVD 2 WMV Guide
meansizzler is offline
audio, auzentech, dacs, prelude, quality, question, unprocessed
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Auzentech X-Fi Prelude 7.1 Gaming Sound card thelawns Sounds Cards, Mics, Headsets and Computer Speakers 182 08-09-2008 11:22 PM
PS3 via Optical SPDIF to Auzentech Prelude No Sound... thelawns PS3 0 09-02-2008 1:46 AM
My Auzentech Prelude just died on me! Leporello Sounds Cards, Mics, Headsets and Computer Speakers 4 08-12-2007 1:11 PM
Auzentech Prelude Problems Rapid7 Sounds Cards, Mics, Headsets and Computer Speakers 0 27-10-2007 3:08 PM
confused about my Auzentech X-Fi Prelude. fastlane88 Sounds Cards, Mics, Headsets and Computer Speakers 1 09-10-2007 6:31 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
