AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Sounds Cards, Mics, Headsets and Computer Speakers
LinkBack Thread Tools Display Modes
Old 08-04-2008, 10:37 AM   #1 (permalink)
Help! Can't get optical OUT to work! :(
I've got a Fortissimo II soundcard. I'm currently trying to get it hooked up to my Azur 340R AV Receiver. However, I can't get it to play any sound whatsoever! I've made sure it's in the soundcard's digital OUT and it goes to the AVR's digital IN. I've selected the right channel on the AVR (Video 2) and also the right audio type to digital.
Anyone have any ideas? I'm going to try and reinstall different soundcard drivers tonight and also take out the soundcard and inspect the digital out connector as it didn't have the cap in it and it's been sitting in my PC for a fair while now (could dust in the optical connection on the soundcard cause a problem???).
Any tips please! Is there anything in Win XP which you have to changed for it to output sound via optical digital? I'm using a toslink Cambridge Audio fibre optic cable.
Thanks guys.
ytrebil is offline
Old 11-04-2008, 10:04 AM   #2 (permalink)
Thanks: Gave 3, Got 11
Re: Help! Can't get optical OUT to work! :(
However you get to control panel>Sounds And Audio Devices>Audio>Dropdown box in Sound Playback
PC: Q6600 @ 3.4 - P5K Deluxe - 4GB Geil Black Dragon 8500 - Scythe Mine - HX520 - 8800GTX AC3S - Sammy F1s 1TB - Sammy 22" SM - Logitech Z-5500
Music: PC>Foobar>M-Audio Revo>Musical Fidelity KW DM25 DAC>Tag PA20R>Senny HD650
ell-ess-dee is offline
optical, work
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Amps that definitely do/definitely don't work with Sky+ optical out Broadz Integrated AV Amplifiers and Receivers 13 27-04-2007 6:47 PM
xbox 360 HD optical input cant get it all to work together!! zultanjak All-in-one Systems 10 15-03-2007 12:15 PM
ps2 optical does not work jamesbond007 PS2 6 26-10-2006 1:59 PM
optical splitter why wont it work? mickymcd Interconnects, Speaker Cables and Switches 2 27-05-2006 7:51 AM
will this work ? digital optical converter waterloo All-in-one Systems 1 23-05-2006 6:55 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
