AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Sounds Cards, Mics, Headsets and Computer Speakers
LinkBack Thread Tools Display Modes
Old 28-03-2008, 3:56 PM   #1 (permalink)
Thanks: Gave 4, Got 12
Still need help with passthrough with soundcard.
Hope someone can help me here.Have a Auzen x-plosion soundcard.I want to send 5.1 signal to my amp so it can do all the decoding dutys.I have connected an optical cable to my amp.It works fine when I send a signal through my card in dolby live or dts connect but I cant get a passthrough signal to my amp.I set my AC3filter on spddiff and passthrough and all my players to spfiff or passthrough stilll no sound.I have tried several codec packs I am using Klite codec pack at the moment.I am stumped now so I hope someone here has the answer I need.
sapper44 is offline
Old 28-03-2008, 8:07 PM   #2 (permalink)
Thanks: Gave 1, Got 10
Re: Still need help with passthrough with soundcard.
oddly enuff i had a similar problem.
I took off ALL the codecs on my machine.
Install K lite FULL only(dont change any settings)
Used a new optical cable,then it started working as it should (passthru)
Sometimes when a problem arises with sound or video we tend to install TOO many codecs,then neither will work properly.
chrispeters is offline
Old 28-03-2008, 8:20 PM   #3 (permalink)
albriscoe's Avatar
Thanks: Gave 307, Got 265
I have to agree with Chris here
we are all guilty of installing loads of codecs for different players to work, uninstall all what you have and start again with one codec pack and leave it at that. if its a 64 bit op system you have such as vista I have found too many problems so changed to 32 bit and now alls well
let us know how you go on
Allan
Click to see my selfbuild/basement cinema
Onkyo TX-NR 905 M&K`s SW150 fronts SW95s rears Sub M&K MX125 Mk 11 SIM Grand Theatre PJ 118" 16.9 fixed screen HTPC Asus AMD2 6000+ CPU LG BD/HD player 4gb DDR2 Ram 5t/b h/drives Panny TH-50PX70 / TH-42PX70 Samsung LE40A756/BD-P 1500 Humax Freesat HD
albriscoe is online now
Old 28-03-2008, 11:06 PM   #4 (permalink)
Thanks for the replies.Think I'v cracked it.My main player is Media player classic added the ac3 filter to the external filter list and seems to have done the job.Thanks again.
sapper44 is offline
passthrough, soundcard
Refbacks are On
Thread Thread Starter Forum Replies Last Post
SKY+ RGB Passthrough sniffer66 Video Scalers, Video Processing and Progressive Scan 1 20-02-2006 9:51 AM
RGB Passthrough saintalan Interconnects, Speaker Cables and Switches 1 08-02-2005 12:43 AM
Sky+ RGB Passthrough Wackojacko32 Sky and Sky+ 0 04-02-2005 12:53 PM
Cheapest Soundcard with DD/DTS passthrough on SPDIF? SimonInd Sounds Cards, Mics, Headsets and Computer Speakers 4 24-12-2003 10:15 AM
Sky+ RGB passthrough Lexus Fan Man Sky and Sky+ 1 29-04-2002 1:39 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
