AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Sounds Cards, Mics, Headsets and Computer Speakers
LinkBack Thread Tools Display Modes
Old 24-03-2008, 6:54 PM   #1 (permalink)
Thanks: Gave 20, Got 10
Audigy2 digital out to RCA on 5.1 system what cable?
Could do with some help guys im trying to find a cable that allows me to run my audigy 2 card with my creative 5100 5.1 system , but I cant find the cables to do the job
I need a 4 conductor miniplug to RCA(Female) cable and an RCA to RCA to connect up to the Audigys digital out - the RCA to RCA shouldnt be a problem but any idea where I can get a 4 conductor miniplug to RCA female ?
Mark
marksovereign is offline
Old 26-03-2008, 4:11 PM   #2 (permalink)
Thanks: Gave 2, Got 121
Re: Audigy2 digital out to RCA on 5.1 system what cable?
The only minijack plugs with 4 poles are AV/CAM cables....
http://cgi.ebay.co.uk/5M-3-5MM-4-POL...QQcmdZViewItem
What are the outputs/inputs on your soundcard and 5100?
Panasonic TH-50PZ70,HTPC T240HD,Toshiba EP30,Sony STR-DE697 (6.1),Maudautshort MSW20 Sub,Kef Cresta Centre,TDL Studio 10's,Gale 3060B Bi-Polar Rears,Gale 20 Centre (rear),Sky+ HD Box,Harmony One Remote,PS3 40GB,PSP (3.90 M33-3),DS Lite (Edge) and a Wii
un1eash is online now
Old 26-03-2008, 4:38 PM   #3 (permalink)
Thanks: Gave 0, Got 6
i dont think you need this. Audigy has 3 analog outputs
that are:
1) front L/R
2) center/LFE
3) rear L/R
that "correspond" to 3 analog inputs on the Inspire 5100 sub/amp
It would be a different ball game if you had 7.1 speakers - only then you would need a special cable.
True: Audigy has digital output but your 5.1 set does not. Unless it isn't 5100. But 5100 is analog-only.
So it is 3x regular 1/8" jack-to-jack cable between the card and the sub/amp and then 5xRCA-to-RCA cables between the sub/amp and the actual 5 speakers...
Erazerhead is offline
audigy2, cable, digital, rca, system
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Audigy2 zs Platinum Pro Help!! krisad13 Sounds Cards, Mics, Headsets and Computer Speakers 2 13-10-2007 4:22 PM
help with audigy2 zs to amp Mac1 Computer Systems 2 23-10-2005 5:54 PM
Audigy2 platinum EX Tom3316 Computer Systems 0 07-04-2004 9:55 PM
anyone got digital out on audigy2 to work? rsvrmille Computer Systems 3 22-09-2003 11:10 PM
audigy2 steevs Computer Systems 0 19-05-2003 5:04 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
