AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Sounds Cards, Mics, Headsets and Computer Speakers
LinkBack Thread Tools Display Modes
Old 17-03-2008, 11:23 PM   #1 (permalink)
Thanks: Gave 1, Got 1
Sound card recommendations for analogue ?
I'm running an HTPC with Power DVD Ultra.
I want to run 4.1 analogue outs. I know some will try to persuade me to go digital and/or get a centre, but please humour me.
Are there any decent sounding cards out there which are able to handle a sub but no centre speaker on all the new formats for BD/HDDVD ?
The on-board (Realtek HD) only allows 4.0 or 5.1 but not 4.1 and is also very noisy (should I think about an external card?).
Grateful for any advice.
nortonl is offline
Old 21-03-2008, 8:16 AM   #2 (permalink)
Re: Sound card recommendations for analogue ?
No-one got a card that can output FL+FR+RL+RR+Sub without centre on analogue ?
Doesn't surprise me. I have downloaded umpteen user guides and they all seem to call 4.1 as 4.0 with bass management in the sub. I guess that's how most PC speakers work.
nortonl is offline
Old 21-03-2008, 12:02 PM   #3 (permalink)
Thanks: Gave 1, Got 12
I guess the problem would be that there is no software I know of that could mix the centre channel into the two front channels. The soundcard itself only does what the software/drivers tell it. Any 5.1 or 7.1 card should theoretically handle it as far as connections go
Prism666 is offline
Old 21-03-2008, 12:41 PM   #4 (permalink)
Thanks: Gave 38, Got 178
I run a 3.1 setup, have the soundcard setup as 5.1 output but since there is hardly any data from the rear channel you really don't miss anything, regarding the 4.0, there must be and option for a quad setup I know there is in the xp control panel but not sure about soundcards, you need to I rememberthe soundblaster Live did 4.0, not sure about 4.1, but them drivers are pretty much dated....
Erm...Yeah, I built a Mac
DVD 2 WMV Guide
meansizzler is offline
Old 21-03-2008, 4:06 PM   #5 (permalink)
Thanks both of you. Getting the centre mixed in to the 2 main channels is no problem - all the cards I've checked can do that but only without a separate LFE channel. I guess I'll live with 4.0 for now and switch to SPDIF for old fashioned DD/DTS.
nortonl is offline
analogue, card, recommendations, sound
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Sound Card Recommendations daniel_owen_uk Sounds Cards, Mics, Headsets and Computer Speakers 27 22-06-2007 2:51 PM
Lots of cable recommendations please (HDMI, coax, speaker, power and analogue) lfletcher HDMI Cables and Switches 7 25-01-2007 11:57 AM
Sound card recommendations - Passing a digital 5.1 stream to decoder Tom Whitaker Sounds Cards, Mics, Headsets and Computer Speakers 16 30-03-2005 12:54 PM
Analogue Output Sound Card Required steverussell Sounds Cards, Mics, Headsets and Computer Speakers 4 18-11-2004 7:02 AM
Digital and Analogue Input Cards Recommendations Wanted Garrett Computer Systems 6 08-07-2004 6:32 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
