AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Sounds Cards, Mics, Headsets and Computer Speakers
LinkBack Thread Tools Display Modes
Old 15-03-2008, 3:02 PM   #1 (permalink)
No sound from HDMI to DVI cable with ps3.
I have my ps3 going into my computer monitor through a HDMI to DVI cable.
What sort of cables do I need to attach speakers to my ps3?
JDRM is offline
Old 15-03-2008, 3:26 PM   #2 (permalink)
Curly99's Avatar
Thanks: Gave 50, Got 369
Re: No sound from HDMI to DVI cable with ps3.
you may be better off asking in one of the PS3 forums.
Curly
Please read the Forum Rules, When posting use the manufacturers full name and model number (where applicable), it makes everyone's life easier
"All opinions expressed are my own and not representative of the AV Forums or any other related website."
Curly99 is offline
Old 15-03-2008, 3:35 PM   #3 (permalink)
I though there might be better advice here..seeing as this as an AV forum.
I bought some good logitech speakers for my computer not so long ago. Does anyone know a way of connecting a PS3 to a standard speaker jack?
JDRM is offline
Old 15-03-2008, 3:41 PM   #4 (permalink)
the mechanic's Avatar
Thanks: Gave 7, Got 23
You will need an optical digital lead as DVI is video only and will not carry audio.
Not sure if the multi AV out has standard phono's for stereo as I have mine connected via HDMI>HDMI and I dont think you can have HDMI output AND multi AV at the same time (HDMI for video and the stereo phonos on the multi AV for audio) if you see what I mean.
Graham.
LG 42pc55.Sony BDP-S550.Denon AVR 2808.Monitor Audio BR2-AV package + BR1 surround rears.Humax 9200T.60 Gb PS3.Harmony 885 URC.NO PLUG SOCKETS LEFT.DEAF NEIGHBOURS.NAGGING WIFE and a whole lotta cables to boot.
the mechanic is offline
Old 15-03-2008, 3:55 PM   #5 (permalink)
If i get a 3.5 stereo male to 2 female RCA lead
can I plug the white and the red RCA from the PS3 into my sound card... which will let me hear sounds from my PS3 and my computer?
Or am i talking rubbish?
JDRM is offline
Old 15-03-2008, 4:17 PM   #6 (permalink)
Yeah, thats the sort of thing you need. But like I said, I'm not sure you can use the HDMI and AV multi outputs at the same time which is what you'll need to do. I would have a go and experiment myself for you but firstly I dont have one of them leads, and secondly, it is a pain to drag my AV stand out and wire the PS3 up in this way.
Sorry,
Graham.
Old 15-03-2008, 4:55 PM   #7 (permalink)
Ok thanks mate! Ill pop down mapin and pick on of the leads up (naturally not today due to our imminent rugby grand slam eh? )
JDRM is offline
Old 15-03-2008, 5:27 PM   #8 (permalink)
james.miller's Avatar
Thanks: Gave 6, Got 121
Sorry,
Graham.
yes you can its how we get around the lag problems with singstar when using hdmi displays
Sony VAIO fw-11s w/ 320gb WD Black hard drive
ONKYO TX-SR805, mission m71i's, panasonic th-50pz80b
ps3: cant remember atm 360 gamertag: JimmyDonWon
james.miller is offline
Old 26-03-2008, 9:33 PM   #9 (permalink)
My cable finally got here!
its all plugged in and ive chosen audio out via component on the ps3 menu, but im not sure where in my soundcard to plug it into?
Could someone help?
JDRM is offline
Old 26-03-2008, 11:44 PM   #10 (permalink)
anyone?
JDRM is offline
Old 27-03-2008, 2:04 AM   #11 (permalink)
Curly99's Avatar
Could someone help?
I would guess that you need to plug it in the mic socket.
Curly
Curly99 is offline
Old 27-03-2008, 2:13 AM   #12 (permalink)
Curly
so did I seeing that thats the only line in.. but Im not getting any sound
JDRM is offline
Old 27-03-2008, 2:27 AM   #13 (permalink)
Curly99's Avatar
Check that the mic isn't muted in the volume options also you may need mic 2 enabled but I think that is driver soundcard option dependent, anyway in the controlpanel/sound and audio devices make sure there's a tick in the microphone select box then select advance and make sure there is a tick in the microphone boost +20db box
hth, Curly
Curly99 is offline
Old 27-03-2008, 7:47 PM   #14 (permalink)
got it working!
thanks a bunch
JDRM is offline
Old 27-03-2008, 10:45 PM   #15 (permalink)
one problem...
the sound quality is really bad in places
the sound distorts bass and drum sounds, is there a way to fix this?
I have the pc's sound at 100 and the ps3's sound at 20 (as they sound equal volume like this)
im also pretty sure that either the left or right audio isnt playing at all...how do i configure this?
JDRM is offline
cable, dvi, hdmi, ps3, sound
Refbacks are On
Thread Thread Starter Forum Replies Last Post
can hdmi cable carry sound ? jamestay1 HDMI Cables and Switches 7 23-12-2007 2:07 PM
DVI - HDMI - Speaker Cable = No Sound! Mechanicus LCD Televisions 6 26-10-2007 12:10 AM
Is the sound worse with HDMI cable?? What can I do? suttonsboot Sky HD 6 08-01-2007 12:27 AM
HDMI Cable and Sound Sydney HDMI Cables and Switches 4 09-05-2006 9:19 PM
Problem with analogue sound when using DVI to HDMI cable rnjmorris LCD Televisions 0 03-09-2005 4:05 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
