AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Sounds Cards, Mics, Headsets and Computer Speakers
LinkBack Thread Tools Display Modes
Old 11-03-2008, 11:48 AM   #1 (permalink)
Thanks: Gave 2, Got 0
Advice On Sound From Xbox360 Through Pc Speakers... Please Assist
Hi everyone,
so here is my situation.... i have a nice 7.1 speaker system connected to my PC, i have a 24inch HD Dell monitor, which allows me to connect my 360 to it via componant, now.. obviously i get no sound, i have an optical port on the back of my PC (im using the integrated sound card at the moment which has this) i tried connecting the 360 via optical to this, however no sound came out of the speakers still...
basically what im trying to ask is, is there a way i can connect a 360 to my PC speakers without having to go out and buy an AMP just for this...? I am thinking of getting a new sound card, is there any sound cards with optical which will decode sound from the 360 and send to the speakers thro the PC sound card without the need of an AMP... all assistance and information on this would be greatly appreciated...
thanks
Sony Bravia 52" X-Series KDL-52, Sky HD, Xbox 360 Elite, Xbox 360 HD DVD Player, PS3 (80GB), KEF 3005-SE, Sony DG 910, Dell XPS 710, Alienware Area-51, Blackberry 8300
retro_games_uk is offline
Old 12-03-2008, 1:59 PM   #2 (permalink)
Thanks: Gave 1, Got 17
Re: Advice On Sound From Xbox360 Through Pc Speakers... Please Assist
this isn't possible due to the underlying constraints of the windows driver model without an annoying delay (anywhere from 20ms to 500ms, depending on the driver). So you're better off investing your money into a dedicated receiver which can drive the speakers then.
http://code.google.com/p/cmediadrivers
dogbert is offline
Old 14-03-2008, 3:27 PM   #3 (permalink)
The optical port on your on-board sound is most likely "optical out" that is why it is not working. If you were to get a new sound card that can recieve optical in I would recommend:
HT Omega Striker (Slightly older chip, Front audio panel connector)
HT Omega Claro (newer chip, front audio panel connector, I have this one)
HT Omega Claro +Plus (same as above but with extra op-amp)
Turtle Beach Montego DDL (Cheapest but no front panel audio connector)
Sondigo Inferno (same chipset as HT Omega claro, but no front panel connector)
so depending on what your budget is and if you care about the front panel connector you can choose whichever suits you best. I have no experience using the Turtle Beach card, but the other 4 cards all use very similiar drivers so I can CONFIRM that I can recieve the xbox 360 digital toslink signal and play it back through my speakers.
HOWEVER, IMPORTANT!
"Taken from http://support.turtlebeach.com/site/.../588318928.asp
"DOES YOUR SOUNDCARD DECODE DOLBY DIGITAL/DTS SURROUND?
For licensing and copyright protection purposes, soundcard manufacturers
are effectively prevented from adding DD/DTS decoders to their products.
The reasoning is that the only legal use of DD/DTS decoders is for playback
of licensed soundtracks from DVD movies. In your PC, a DVD player software
must decode your DD/DTS soundtrack, NOT the soundcard.
Many customers have asked us how to use the S/PDIF Digital Input to decode
surround sound from external players such as the Microsoft Xbox 360,
standalone DVD players or other computers. Because of the above-mentioned
licensing and copyright protections, this is not possible.
However, you can use a home theater receiver, or one of the new Home Theater
In a Box (HTIB) powered speaker systems from Logitech, Samsung and others.
Both of these product types have built in DD/DTS decoders, so will accept
an incoming data stream from the Digital Out of Turtle Beach PCI soundcard
and USB sound products.
Our Montego DDL *encodes* game audio to the new Dolby Digital Live format,
so you can hear positional audio from your PC games. It DOES NOT decode DD/DTS
soundtracks. Again, you need a DD/DTS decoder, either a software version or a
hardware decoder in your home theater receiver or Home Theater in a Box. ""
So in short, No there is no card that decodes Dolby or DTS.
HOWEVER there is a solution. Go the xbox360 system panel in sound and change the digital output to "Digital Stereo" this will output digital PCM. But you will only get 2.0 sound. You can get your sound card to upmix it to 5.1 or 7.1 through the DSP's onboard but I don't know what that will sound like. I personally only have 2.1 speakers and headphones so it doesn't matter to me.
If you get a sound card such as the ones you mentioned it should work fine. I just got the claro and I can listen to the spdif input. However one more problem though. To listen to the spdif in, you have to go to the control panel for the card and click "monitor" on the input for spdif in. When you do this, on the driver provided by the manufacturer it will not allow you to adjust the volume. This may or may not be a problem if you're using speakers that have its own volume adjust. But you can work around this problem by using the reference drivers provided by c-media and it works flawlessly.
So there is no way to recieve the 5.1 sound from your xbox into your pc and beable to decode it as far as I know. If you really want that 5.1 digital sound I recommend you either buy a reciever or the these logitech 5.1 speakers that you can hook up directly to the xbox that will decode 5.1 sound for you
http://www.logitech.com/index.cfm/sp...s/224&cl=us,en
EDIT : Oh and about the delay, as far as I know there is little to no delay, because when i'm listening to the signal i'm just monitoring the spdif-in on the soundcard, I believe the delay is less than 20ms because I tried to play the sound back in recording software with ASIO drivers setting the delay to 20ms and the sound coming out of the "monitoring" of the spdif-in from the sound card control panel was still heard first so I am pretty sure its less than 20ms. That is not much of a delay.
Pockymonster is offline
Old 24-03-2008, 11:40 AM   #4 (permalink)
Thanks: Gave 1, Got 0
also the Razer Ac-1 has optical in as well and can be found for under 50$ on the net.
Godspeed.
IcedOmega13 is offline
advice, assist, sound, speakers, xbox360
Refbacks are On
Thread Thread Starter Forum Replies Last Post
KEF 3005 SE, Sony 910 DG need advice for Cables, please assist! retro_games_uk Interconnects, Speaker Cables and Switches 4 04-03-2008 3:25 PM
Advice on speakers for Surround sound Stevie LA Speakers 0 26-10-2006 8:32 PM
Surround sound speakers advice if you please JamieBee Speakers 5 28-07-2006 9:39 PM
Sound Card and Speakers Advice Please raven219 Sounds Cards, Mics, Headsets and Computer Speakers 7 28-02-2006 11:34 AM
Sound advice... (Card & Speakers) PFM Sounds Cards, Mics, Headsets and Computer Speakers 0 02-01-2004 7:54 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
