AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Sounds Cards, Mics, Headsets and Computer Speakers
LinkBack Thread Tools Display Modes
Old 07-03-2008, 9:15 AM   #1 (permalink)
Thanks: Gave 2, Got 1
Asus A8N SLI Premium - Use the optical or S/PDIF to my amp
HI
I have the asus A8N SLI Premium board, this motherboard provides connectivity to external home theater audio systems via an optical or coaxial S/PDIF-out jack. It allows to transfer digital audio without converting to analog format and keeps the best signal quality.
I was wondering what would be the best way to connect to my amp S/PDIF or optical.
Any advice much appreciated.
irishkeet
HTPC - MCE 2005. ASUS A8N-SLi Premium, AMD 64 X2 3800, 1024MB Corsair XMS, Gigabyte 6600GT, 500GB Samsung SpinPoint T, SweetSpot MCE DVB tuner, Tagan TG480-U15, Silverstonetek LC13S, DVD ROM.
Kit - Samsung LE37R88BD - Yamaha DSP-AX750SE - Canton CD1.
irishkeet is offline
Old 07-03-2008, 9:52 AM   #2 (permalink)
Thanks: Gave 6, Got 3
Re: Asus A8N SLI Premium - Use the optical or S/PDIF to my amp
Dont think it makes a whole lotta difference TBH. Its probably more down to the amp and how well it deals with each input, also maybe the length of cable run you plan to use. I believe optical is better for longer distances.
pinkerton is offline
Old 07-03-2008, 12:42 PM   #3 (permalink)
thanks
cable withh be half meter
just wondering if optical will offer better quality
a8n, amp, asus, optical, premium, s or pdif, sli
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Asus A8N-VM CSM and S/PDIF richjthorpe Computer Systems 4 17-03-2006 3:58 PM
Motherboards with S/PDIF optical out? ozdick Motherboards, CPUs, Cases and PSUs 7 19-01-2003 12:22 AM
S/Pdif on Asus A7V8X pcpaz Computer Systems 6 10-01-2003 1:03 PM
S/pdif & Optical Leads pcpaz Computer Systems 2 15-12-2002 2:34 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
