| AVForums.com is the UK's biggest & best home consumer electronics discussion resource | New to AVForums.com? Start by reading our introduction here. |
#1 (permalink) |
Behringer C-1 Question
I do alot of VOIP and I was using this mic: http://www.maplin.co.uk/module.aspx?...&doy=29m2#spec Until it stopped working. I even used it the plug into my MiniDisc and when a subject was a good meter away it produced amazing results for just £20. I would like to try something else though and I have come accross this: http://www.dv247.com/invt/28184/ Theres a problem. Its XLR, so I need an XLR to 3.5mm gold connection, cable to connect this to my PC mic socket. I also read I need a preamp? The reason why I liked the mic above so much is because it had a battery and was louder than me plugging a normal dynamic mic in because it had a battery I suppose it gave it a boost in volume, will this mic have that boost of volume? Could I use it over the head of a subject (a bit like a boom mic in the films) but still produce good quality for VOIPing So how can I use this mic to support my MiniDisc and computer both 3.5mm plugs. Thanks |
| Bookmarks |
| Tags |
| behringer, question |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Behringer A500 | nwhitta | Audio Processors and Power Amps | 0 | 25-02-2006 8:49 PM |
| Which Behringer? | compact7 | Subwoofers | 22 | 04-02-2006 3:09 AM |
| What's wrong with this Behringer sub??? | Badger0-0 | Subwoofers | 2 | 13-01-2006 6:52 PM |
| Question about Behringer Feedback Destroyer | dunkyboy | Speakers | 3 | 03-06-2003 8:52 PM |
| Behringer DSP2024P - How to set it up ?? | Darbyweb | Plasma Televisions | 2 | 26-05-2003 4:48 PM |
Global Gold Web Hosting |
