AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Sounds Cards, Mics, Headsets and Computer Speakers
LinkBack Thread Tools Display Modes
Old 24-02-2003, 9:57 PM   #1 (permalink)
daninthemix
Posts: n/a
Sound card with digital out
Dear all,
Can anyone tell me the cheapest, simplest way to get a PCM stream out of my computer, so I can run it into my AV system about 10 metres away?
I don't want a huge soundcard with bells and whistles on (or a front panel for that matter!), I just want one that can send PCM data straight out over coax (or optical since it's quite a distance) for decoding by an AV processor.
Best solution is a card with one digital output and nothing else that costs £10
...but I'll happily accept the closest alternative...
Old 24-02-2003, 11:20 PM   #2 (permalink)
I have an SBlive 5.1 sound card which has an SPDIF output socket. You will need a interconnect with a mono-jack plug on it. I would let you have this for £15 plus p+p if you are interested.
Dave
Dangerous is offline
Old 24-02-2003, 11:27 PM   #3 (permalink)
daninthemix
Posts: n/a
So you're offering a soundcard with digital out for £15 then? Yes I'm definitely interested! Can you PM me an address to send the cheque, and any info on where I can get the 3.5mm jack-to-spdif cable from then?
Old 25-02-2003, 6:11 AM   #4 (permalink)
Oli
Thanks: Gave 1, Got 1
Sorry, but have you ever got it to work? I havent, even with the right cabling!
Oli is offline
Old 25-02-2003, 6:17 AM   #5 (permalink)
Charlie Whitehouse
Posts: n/a
Dan,
You're surely not going to put the output from a £15 sound card into your new ?????????? Oh, the pain, the pain!!
Old 25-02-2003, 12:01 PM   #6 (permalink)
Steve1138
Posts: n/a
I bought the TERRATEC Aureon 5.1 Fun
the cheapest one in the new AUREON range.
Has optical in and out
Seems to work fine so far
Old 25-02-2003, 2:02 PM   #7 (permalink)
daninthemix
Posts: n/a
Steve1138 - thanks for the info. I've ordered the Terratec, since Toslink seems more suitable for connecting over 10 meters.
Charlie - the Terratec costs a more reasonable £28. Have I allayed your fears
Old 25-02-2003, 4:44 PM   #8 (permalink)
Thanks: Gave 2, Got 6
Over 10m!!!????
The cable will cost you more than the sound card =) I also think you will get signal degredation over that length. IIRC, coax is better over long distances, I could be wrong.
Toshiba 32ZP18P 32" Widescreen, Pioneer VSX-D2011S, Parasound 1205A, JM Lab Electra 926, SVS PC Ultra, Philips DVP5900, Arcam CD72T, Corda Aria --> Sennheiser HD580 / AKG K 701
Daneel is offline
Old 25-02-2003, 8:28 PM   #9 (permalink)
daninthemix
Posts: n/a
Already ordered the cable - £25 for a 10m optical. Lack of signal degradation over long distances is one of the main reasons optical exists - it's coax that you have to watch over lengthy runs due to greater chance of RFI/interference and also weakening of the electrical signal.
Old 25-02-2003, 10:37 PM   #10 (permalink)
Daninthemix
I take it you do not want the card, no problem just thought I would offer you a cheap option.
Oli
I have been using this card to supply a signal to my Yam A1 witout any problems.
Dave
Old 26-02-2003, 1:36 AM   #11 (permalink)
Oli
Can you explain to me how? I have spent ages tryin to get it to work, never had any luck!
Oli is offline
card, digital, sound
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
