AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Sounds Cards, Mics, Headsets and Computer Speakers
LinkBack Thread Tools Display Modes
Old 07-04-2002, 10:49 AM   #1 (permalink)
Advertiser
Thanks: Gave 19, Got 100
DIY hard drive sound reduction with pictures
Here is a simple way to reduce the noise from a hard drive, when used in a desktop case.
Two pieces of foam are simply wrapped around the drive and secured with tie wraps.
A hard drive sounds noisy because the case resonates with the head movement etc.
So decoupling the drive from the case makes things much more peaceful.
If you choose a drive that is already fairly quiet, then mounting like this makes it really quiet.
An earth wire is attached, because if the drive was screwed to the case it would be earthed.
The drive simply sits on the bottom of the desktop case under the DVD drive.
If you get the amount of foam just right, the drive is a fairly tight fit in the case.
You could attach a PAPST 12 db fan to the drive if you are concerened about heat.
Foam attached to the drive.
Side view, air gap underneath and Earth wire.
Acoustic cushioning close up
Happy tweaking,
Mark G.
Mark Grant is offline
Old 07-04-2002, 10:54 AM   #2 (permalink)
Thanks: Gave 4, Got 40
That would scare the hell out of me m8
HD's run very warm so wouldn't this foam start to melt with the heat?
How long have you had the drive running like this?
alanrob is offline
Old 07-04-2002, 11:22 AM   #3 (permalink)
Advertiser
Hello Alan,
A hard drive has a max temp of about 55 Centigrade.
Not sure what melting point of foam is, but will be more than that.
Been running since about christmas like that, no problems so far.
I will attach a thermistor under the foam, touching the metal of the drive, just to see what sort of temperature the drive runs at when on all day.
Will post more later today.
Mark.
Old 07-04-2002, 1:07 PM   #4 (permalink)
It'll be interesting to see what the temp difference is with and without the foam. Looking forward to your results.
Now, where did I put that foam
alanrob is offline
Old 07-04-2002, 9:46 PM   #5 (permalink)
Advertiser
The PC has been running for 10 hours now.
The surface temperature of the hard drive is 44.5 degrees C, with a room temperature of 21 degrees C.
So no problem with heat
The hard drive is an IBM 5400 rpm, nothing special.
The PC spec is a P3 933 slot 1 with a quiet PC Molex cooler, the standard PSU has a PAPST fan fitted, a bit slower than a standard fan, but fairly quiet.
No other fans in the case, airflow is a bit limited, so could be cooler.
Must get some of the PAPST 12 db fans sometime.
The case is lined with Brown bread, a product similar to Dynamat, but costs less. This makes the case really heavy and dead sounding, unlike the usual tin can PC case sound.
link to a site selling brown bread. One roll is more enough for a desktop PC case.
Someone else going to try this?
Good luck,
Mark.
diy, drive, hard, pictures, reduction, sound
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
