| Re: advice on getting the best quality audio from my PC.
If your soundcard is decent, then it will probably provide as good a sound if not better via 3.5mm output over optical. Alternatively, get a soundcard that has 2 x RCA output. There are a few around now I believe that dont cost the earth, I think the Auzentechs might do that. My Creatives Breakout Box has 2 x RCA I believe but I cant remember now if thats line in or out..lol
From my PC which has a X-Fi Fatality Champion Series card to my Denon 3803 AV amp, the 3.5mm output is just as good as the optical connection. What I might try though this week as I'm off work is to run my soundcard via optical through the 3803, then use the pre-outs to my Musical Fidelity A5 amp and see how that works against a direct 3.5mm to the A5. Essentially the optical to the 3803 then pre-outs to the A5 is simply using the 3803 as a DAC, and it has some good DACs inside, better than those in your Cambridge Audio. Be interesting to see which works best there. Yay, a project for my week off work...lol
