I have same problem here ,components as follows Ati 4870 card connected through the ati adapter to my Yamaha Rx v868 then to my Pioneer plasma .
Ati control shows DVI instead of HDMI therefore no sound .
When i connect the card directly to the tv it shows up as a HDMI device on the control panel but it is only two channels.
I have installed the latest 8.10 drivers and the latest ATI HD AUDIO DRIVERS FROM REALTEK. TO NO AVAIL..
I think there are two options for me:
1. delete the Edid reg entries
2. use Vista
Or is there another?
Monitor
Model name............... RX-V1800
Windows description...... Plug und Play-Monitor
Manufacturer............. Yamaha
Plug and Play ID......... YMH3116
Serial number............ n/a
Manufacture date......... 2007, ISO week 0
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. Undefined or variable
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... n/a
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,625 - Ry 0,340
Green chromaticity....... Gx 0,280 - Gy 0,595
Blue chromaticity........ Bx 0,155 - By 0,070
White point (default).... Wx 0,283 - Wy 0,298
Additional descriptors... None
CE video data (timings supported)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1) [Native]
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
1440 x 480p at 60Hz - DVD (4:3, 4:9)
1440 x 480p at 60Hz - DVD (16:9, 16:27)
2880 x 480i at 60Hz - Console (4:3, 2:9-20:9)
2880 x 480i at 60Hz - Console (16:9, 8:27-80:27)
2880 x 480p at 60Hz - Console (4:3, 2:9)
2880 x 480p at 60Hz - Console (16:9, 8:27)
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
720 x 576i at 50Hz - Doublescan (4:3, 16:15)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1440 x 576p at 50Hz - DVD (4:3, 8:15)
1440 x 576p at 50Hz - DVD (16:9, 32:45)
2880 x 576i at 50Hz - Console (4:3, 2:15-20:15)
2880 x 576i at 50Hz - Console (16:9, 16:45-160:45)
2880 x 576p at 50Hz - Console (4:3, 4:15)
2880 x 576p at 50Hz - Console (16:9, 16:45)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
LPCM 8-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
AC-3 6-channel, 640k max. bit rate at 32/44/48 kHz
DTS 7-channel, 1536k max. bit rate at 32/44/48/88/96 kHz
SACD 6-channel at 44 kHz
DD+ 8-channel at 44/48 kHz
DVD-A 8-channel at 48/96/192 kHz
DTS-HD 8-channel, 16-bit at 48/96/192 kHz
CE speaker allocation data
Channel configuration.... 7.1
Front left/right......... Yes
Front LFE................ Yes
Front center............. Yes
Rear left/right.......... Yes
Rear center.............. Yes
Front left/right center.. No
Rear left/right center... Yes
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 0.3.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 165MHz
Data payload............. 00
Re: Unable to selcet ATI HDMI Audio when connected to Onkyo TX-SR606
Has any headway been made on this problem? I just setup a new Onkyo 806 connected to my HTPC with an ATI 4650 and it reports as a DVI connection. I'm running Cat 8.11 with Realtek 2.03.
I did have the problem of no sound with my ATI HD 3650 and Onkyo SR606, but, yesterday, after using Wo0zy's research, I found that the problem was resolved by routing the HDMI cable from the computer into HDMI input 1 on the SR606 (it only works with HDMI input 1, and not he other 3 HDMI inputs). Only then did it register as a "DTV" device in Catalyst Control Center and not a "DVI".
I was having the same problem on my Onkyo 706 and Dell Studio 1735. Thanks to this thread, I have audio. I loaded the latest Catalyst and Realtek ATI HDMI drivers. The Onk display sometimes says Dolby Digital in the lager brightblue letters and always has the smaller, red Dolby Digital on. But I can'tget actual 5.1 to play. Not from videos or from DVD's. Any ideas?
I have a Onkyo 706 and my HTPC is on hdmi4 (game/tv)
No audio on this port and not selectable in windows xp.
I wil try tomorrow the hdmi port1 on my onkyo 706 and will let know the outcome.
My sattelitebox is on hdmi3 and there I have (stereo) sound.
I have had chance to play further today and my findings are as follows,
To ouput sound from the 2400 pro card with the dvi - hdmi adaptor you need to output in either 1280 x 720 (720p) or 1920 x 1080 (1080i).
This appears to be the only way that the Onkyo905 can understand the signal and use it which makes sense.. This is also the case with a 32" Sony lcd i have it will only work with a 720p resolution.
My problem now is that i have a border around the screen on my Pioneer 508 about an inch wide all around the picture.
Also I have only been able to get 2 channel sound so far and idea's
I have binned all the ATI application stuff and it is saying under display adaptors ATI Radeon HD 2400 I am using driver ver. 8.541.0.0
I changed the hdmi cabel to the dhmi port 1 (DVD) and now I have sound and windows see the hdmi port..
I use a gigabyte motherboard and the onboard hdmi (780G).
So for now I'm happy...
Thanks woozy for all the helpful advice. I have the same problem with an HSI 3870 X2 and my new Onkyo sr576. I'm using Catalyst 8.12, realtek 2.13. The audio work with a direct hdmi connection to my Samsung TV but not to my Onkyo AVR. I haven not tried source 1 yet but either way it is rediculous that it has been over 6 months and this issue has not been resolved by ATI. My sound and video works fine from my Xbox 360 with HDMI.
OK Guys,
I made progress!!
1. First get the latest 9.1 Catalyst drivers. There is a good chance your card is not yet supported so please search for drivere .inf modding. Try latest "Mobility Modder", it should work, follow the instructions on their site.
I have problems with no sound via HDMI again...
My config is as follows:
Vista Home Premium x64
ATI HD4850
Yamaha RX-V663
Drivers: Realtek HD Audio Drivers 2.14, Realtek ATI HDMI Audio Device 2.13, Catalyst 9.1, modified EDID for RX-V663
It was working fine (PCM, DD, DTS) until I have connected HDMI repeater and 2nd HDMI-HDMI cable to it. Now I can see HDMI logo on my receiver but no sound comes in. I also got this warning from ATI driver:
"An HDMI to DVI display connection has been detected. In order to hear audio on your HDMI based TV or display, you will need to have a separate audio connection from your computer sound outputs to your TV or audio equipment."
Hey.
I have the same problem.
I'm using:
Vista 64
EAH 3650
Onkyo SR606
Drivers:
1º - Display Driver; ATI WDM Integrated Driver; Catalyst Control Center v.9.10
2º - Realtek HD audio drivers v.2.36
3º - ATI HDMI Audio Device v.2.35
I'm using HDMI port 1 in Onkyo 606.
And my connection HDMI is "not plugin".
And when i go to setup in my onkyo 606 and chose HDMI 1 for audio appears this message:
“An HDMI to DVI display connection has been detected. In order to hear audio from your HDMI based TV or display you will need to have a seperate audio connection from your computer sound outputs to your TV or audio equipment”
Hi Jocker_Boy,
please check this:
1. is DVI-HDMI Adaptor (from ATI) connected to the correct port on the graphhics card? (check your documentation)
2. do you see 2nd display in ATI Control Center (Onkyo itself or TV connected to Onkyo)?
3. display is extend to 2nd display (connected via HDMI)
4. default device for playing audio can be set in Windows to ATI HDMI audio device (not sure exatly about the name, using another PC now)
1. the dvi-hdmi adaptor is yeloow and is in the correct port.
2. i only see onkyo display, and appears as dvi, not hdmi
3. i only see one display
4. i can't select hdmi, because the ccc identify my onkyo as dvi and not hdmi.
