C905 Problem
I was outside cleaning the guinea pig hutch when my c905 slipped out my pocket and landed in a very small pool of rain water. Terrified, i grabbed it, wiped the water off and checked if it worked. It did! Around 30mins later i was on a train surfing the web on my C905 and all of a sudden four buttons stop working: the right button, the 4 button, the 6 button and the 0 button. So i switched it off and it went smooth and tried to turn back on, it wouldn't. I removed and reinserted it but still no luck. When i got back home i tried to turn it on with the help of the charger-no luck. The next day i tried again and it worked! But i had the same button problems. An hour later, i turned it off and it would not turn back on. Even worse it did not respond to charing at all! However, it does respond to connecting it with my pc and it goes into mass storage mode but refuses to go into phone made. I attempted to update the phone but it already had the latest firmware. So what do i do now? It doesn't seem to be working at all.
