I've just purchased a W995 on 3 and I'm wanting to use my T-Mobile simcard in it.
I thought I had nothing better to do than to get it unlocked but someone has told me that if I do this it will keep the 3 branding which is something I was unaware of.
Will I be ok to just get the phone unlocked or would I be better off getting it flashed ?
I've heard horror stories about flashing phones so I'm really unsure what to do for the best.
I should be getting the phone tomorrow so ideally I want to get whatever needs doing to it done asap so that I can start using it straight away.
Any advice would be much appreciated
