3.5 million visitors each month
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
Latest AVForums Movie Reviews
Star Wars: The Clone Wars Blu-ray ReviewPublic Enemies - Original Motion Picture Soundtrack CD ReviewAudition Blu-ray ReviewPolice Story Blu-ray ReviewYear One Blu-ray Review
The Living Dead At Manchester Morgue Blu-ray ReviewPublic Enemies Blu-ray ReviewGojira Blu-ray ReviewHalloween II Original Motion Picture Score - Expanded 30th Anniversary Edition CD ReviewStar Trek - Complete Original TV Show Season 2 Blu-ray Review
Denon 1909 and Panasonic BD35 HD audio issues JonnyP24 Denon Owners' Forum 17 30-05-2009 7:37 AM
Rubbish picture on Setanta/Setanta HD? jamesy999 Freeview 4 13-03-2009 5:57 PM
Rear speakers to go with MA HD range Sonofabeesting Speakers 8 03-03-2009 8:32 PM
2nd hand sky+ box....ITV problem NinjaBaz Sky and Sky+ 17 03-03-2009 2:37 PM
24" Full HD HDMI monitor £175 Simon Coates Xbox 360 Hardware 1 02-03-2009 11:39 PM
Old 02-03-2009, 2:04 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Sky HD and Sky+ Multi room extension
I have a Sky HD box in the lounge and a Sky+ box in the master bedroom.
I am looking to set up the sytem so that I can view and control both boxes from the 2nd bedroom and also the conservetory.
Ideally I would also like to view and control the DVD and XBox that is in the lounge in the conservetory.
I have looked at some Video senders and have tried one but the qualityis very poor and need help to find the right equipment need.
Any help is appreciated
j444rvy is offline   Reply With Quote
Old 02-03-2009, 2:20 PM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,328
Re: Sky HD and Sky+ Multi room extension
Hi this can be done but it isnt cheap and requires specialist cabling and equipment if £5k doesnt scar you off its easy done.....
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
j444rvy (02-03-2009)
Old 02-03-2009, 2:32 PM   #3 (permalink)
Thanks: Gave 6, Got 199
You do not say what video quality you are looking for. Is RF quality good enough?
Stevenage Neil is offline   Reply With Quote
Old 02-03-2009, 3:02 PM   #4 (permalink)
not too bothered about quality, doesn't need to be HD so long as it's a clear picture
Old 02-03-2009, 4:24 PM   #5 (permalink)
The Sky boxes signals can be transported over a single co-ax, the problem arises over how many people, simultanously, need to control both boxes. What is your worst scenario?
Old 02-03-2009, 4:27 PM   #6 (permalink)
the worst case senario would be 2 rooms trying to control either box
Old 02-03-2009, 4:55 PM   #7 (permalink)
The conservatory and bedroom2? (I am assuming that if anyone was in the lounge or bedroom1 they would have complete control of their box)
Old 02-03-2009, 8:08 PM   #8 (permalink)
yes, the main rooms will have the primary control of the units. I was thinking that I could possibly just use the magic eye thing but can I split this so that there are 2 rooms that can control the box?
Old 03-03-2009, 9:31 AM   #9 (permalink)
Originally Posted by j444rvy View Post
...can I split this so that there are 2 rooms that can control the box?
That's the problem - which box? Use of Eyes, in the configuration above, will change both boxes simultaneously.
You could run separate RF feeds from both boxes to both rooms with two Eyes in each room and "cover up" the eye you do not wish to use at any one time, but I suspect this is not what you want.
You may have to lower your expectations of what you want to watch/control from where.......
Neil
extension, multi, room, sky
