Sky + Installation
Old 18-09-2003, 11:20 AM   #1
zafira
Posts: n/a
Sky + Installation
Finally jumped aboard the DVR bandwaggon as the price is right .
getting mine installed on Sunday HURRAY !
Have bought an toslink .
Any things I should look out for , and need to be aware of on the installation - currently ungrading from Digital .
Old 18-09-2003, 11:41 AM   #2
Desticado's Avatar
7,948, Level: 21
Points: 7,948, Level: 21 Points: 7,948, Level: 21 Points: 7,948, Level: 21
Thanks: Gave 2, Got 0
yeah.... make sure they actually fit it!!!
read my thread...
Sky - Yet more AWFUL service...
Old 19-09-2003, 11:12 AM   #3
rnjones
Posts: n/a
Just had mine "sort of installed today". Sky bloke wouldnt change the LNB on the dish on my Chimney so he put a whole new one on the wall. Looks OK to me but the other half will be having words, no doubt.
Sky + box came out of the most shagged packaging you have ever seen. No remote or scart in the box. Was a V2 box though.
+ box couldnt find the transponders even though signal was good. Box was shagged. Sky bloke rang one of his mates who is supposed to bring another one round later today.
Hope its a new one. First Sky bloke said he had a V1 box in his van. NFI, (Not F***ing Interested) was my reply.
Its good to be patient I suppose.
Shouldnt we expect a new box even though it "only" cost £199?
Rog
Old 19-09-2003, 2:13 PM   #4
xyznicko
Posts: n/a
You are entitled to a new box, you are not buying second hand.
Old 19-09-2003, 3:10 PM   #5
Desticado's Avatar
7,948, Level: 21
how do you spot a V1 from a V2?
Old 19-09-2003, 3:30 PM   #6
rnjones
Posts: n/a
Right the Sky bloke came back an hour ago with a new box. Worked first time.
The V2 box is basically white and much smaller than the V1 box which is black and silver I think. The packaging it came in said V2 as well.
The V2 box is a smidgen wider than my old Panasonic STB so it just fitted nicely.
Box seems to make a fan/disc like noise which is 100 times quiter than my PC but there all the same.
Solution .. turn it up.
Rog
Old 19-09-2003, 4:18 PM   #7
4,548, Level: 15
Points: 4,548, Level: 15 Points: 4,548, Level: 15 Points: 4,548, Level: 15
Thanks: Gave 1, Got 2
and what are the main differences/advanatges over the Mk2 to Mk1 box?
Old 19-09-2003, 4:51 PM   #8
Illustrious Member
Starburst's Avatar
40,668, Level: 49
Points: 40,668, Level: 49 Points: 40,668, Level: 49 Points: 40,668, Level: 49
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 239, Got 1,047
Yes all new hardware should really enter your home in a sealed retail package complete with manuals/remote and batteries.
Anything less surely points to someone along the supply chain either stealing or replacing brand new hardware with refurbished/old items. Even damaged packaging should raise the eyebrow, after all how many of us will avoid the dinted tin of beans
Old 19-09-2003, 5:00 PM   #9
rnjones
Posts: n/a
Difference mainly between V1 and V2 is size and possibly internal electronics. But from a users point of view its smaller and a different colour.
Now about the fan noise on Sky + any ideas?
Rog
