| Re: HDMI lead connecting sky+ box to TV
Hmm,
Regarding 'makes' of HDMI cable, there shouldn't be much to worry about here, the signal going down HDMI is digital, as opposed to analogue, so the make and quality of cable is more of a misnomer (or fear-driven marketing) than anything you should need to worry about.
No need - my opinion - for you to go spending £££s on an expensive HDMI cable... you may be best advised staying clear of the most basic of cables at the very, very low-end, but everything else should serve fine - especially if the run is not long, which it won't be.
But, as said above, you can't do it anyway from Sky+.
Moral is, I think, don't get ripped-off with expensive HDMI cables. No real need.
Cheers, DpM
