AVForums - Free Audio Visual electronics advice and information
AVForums.com twitter page AVForums.com facebook page AVForums is a member of CEDIA. THX certified reviewer.  Click for more information. AVForums reviewers are ISF Certified.  Click for more information.
Forum List Register Blogs Information Social Groups Search Today's Posts Mark Forums Read
Go Back   AVForums.com > Forums > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
Home Cinema Podcast
Fri, 16 Jul 2010
Play Home Cinema Podcast : 16th July 2010
We discuss the TVs recently reviewed, including Sharp Quattron and 3D TV.
 Duration 48:33
Latest AVForums Hardware Reviews
Panasonic VT20 (TX-P65VT20B) ReviewAcoustic Energy Aegis Neo V2 Series ReviewLG 15 inch OLED TV (15EL9500) ReviewPhilips 7000 series LED (37PFL7605) Review
Movies Podcast
Fri, 16 Jul 2010
Play AVForums Movies Podcast : 16th Jul 2010
We talk about the latest Blu-ray news.
 Duration 1:00:11
Latest AVForums Movie Reviews
Lock Up Blu-ray ReviewThe Prowler Blu-ray ReviewGalaxy of Terror Blu-ray ReviewBounty Hunter, The Blu-ray ReviewHachi: A Dog's Tale Blu-ray ReviewForbidden World Blu-ray Review
LinkBack Thread Tools
Old 22-11-2008, 1:52 PM   #1
Thanks: Gave 5, Got 0
Sky + with one feed
I am currently living in an apartment with a communal dish and have a Sky+ box recieving two feeds to my sky + box.
However, I am in the process of moving and the new place has a communal dish supplying one feed to each flat.
I understand that I can use my Sky+ box with only one feed, recording only the channel that i am currently viewing.
Is it possible to install another dish and run the cable from that into the Sky+ box, and get the full functionality?
If so, where do I get another dish from? Ideally it would have to be a small dish, that I could install on my balcony? Any ideas? And if so, how would I install the dish?
Thanks.
ande-s is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on FacebookShare on Twitter
Old 22-11-2008, 2:35 PM   #2
fernandez's Avatar
Thanks: Gave 12, Got 886
Re: Sky + with one feed
You only need the standard Sky 45cm mini-dish (complete with LNB) and, of course, a balcony which faces in the direction of the satellite (south)
These dishes are available from hundreds of places and have a look on ebay
Installation help here
Installing a Sky dishInstalling a Dish
If you've got a problem, someone else has had it before you
fernandez is online now
Old 22-11-2008, 2:41 PM   #3
Thanks: Gave 1, Got 3
You could also buy a multi connection LNP and connect it to the existing dish with 2 cables to your box...quad ones are readily available on e-bay
PathUK is offline
Old 22-11-2008, 2:48 PM   #4
fernandez's Avatar
Not really as it's a communal system providing feeds to several flats the output from the dish is already fed to a distribution system.
BTW - it's LNB not LNP
Also, it is not the OP's dish - it belongs to the owners of the building
Old 22-11-2008, 8:18 PM   #5
yeah, sorry - I've got a bit of a cold...
PathUK is offline
Old 24-11-2008, 9:28 AM   #6
Thanks guys. I'll have a look at getting an additional dish then.
I once heard that you can get dishes that don't look like a standard Sat dish, for places that don't allow dishes to be placed on outside walls. Is this true, and if so where would I get one?
ande-s is offline
Old 24-11-2008, 10:29 AM   #7
fernandez's Avatar
Disguised dishes aren't cheap unfortunately
The Sqish - A discreet hidden alternative to a satellite dish - Works with Sky and Freesat
SatEuropa.co.uk: Digi Globe Patio Dish
Cheaper solutions here
Hiding satellite dishes
ande-s (24-11-2008)
Old 24-11-2008, 1:35 PM   #8
45cm Square Satellite Dish with LNB > Maplin
Would that be suitable?
ande-s is offline
Old 24-11-2008, 1:44 PM   #9
fernandez's Avatar
Would seem to be as it claims
"Performs as well as a 65cm Zone 2 mesh dish"
and the Sky Zone 1 dish is 43cm/45cm - and a *lot* cheaper
example: Sky/BBC/ITV 43cm Zone 1 Satellite Mini Dish + LNB on eBay, also, Other Satellite Cable, Satellite Cable Freeview, Consumer Electronics (end time 14-Dec-08 21:04:43 GMT)
ande-s (24-11-2008)
Old 24-11-2008, 1:51 PM   #10
I know that the standard dishes are a lot cheaper, but unfortunately, I'm not able to install one on the outside of my house due to the restrictions of my tenancy.
The square dish would look a lot less obvious, especially if it is possible to paint it.
ande-s is offline
Old 24-11-2008, 2:10 PM   #11
Hi, found this news post today, was wondering if anyone has experience of installers using it yet to solve the years old problem of Sky+ & multi-room from a single feed.
Sky To Deploy Channel Stacking Multi-switches To Single Cable Homes | PVR Junction
As you can see, it's a fully sky approved solution and available now, my personal question is how much does it cost and can it be fitted on a customer basis or is it up to my factor to install for all residents ?
ramsayn is offline
Old 24-11-2008, 3:51 PM   #12
Thanks: Gave 3, Got 514
It is a viable proposition providing that
1 There are spare outputs on the existing multiswitch - otherwise upgraded multiswitches with further outputs will be required
2 High quality satellite cable has already been installed and it is not of excessive length.
There are a couple of similar solutions one that will give two feeds down one cable (Stacker/Destacker and similar), another that will give four feeds down one cable BUT both require the requisite number of free outputs from the multiswitches. It is possible subject to the above provisos on either an individual or communal basis via the people responsible for your installation
Sky HD,Amstrad PVR3,Pace Twinview,Technomate TM9100,Fortec Star 5100 CI Diamond + Dragon,Targa TSR5200 PVR + TRex,Digifusion FVRT200,Tevion PVR801,Wharfedale DVRD24HD160F,+lot more
davemurgatroyd2 is offline
Old 24-11-2008, 11:41 PM   #13
Thanks: Gave 1, Got 0
Sorry I am having the same issues.
1) I am a little confused - is the multiswitch built into some boxes or can you buy a separate multi switch and use with the sky + box I have just purchased?
2) What do the multi switches look like?
Russell
rfryer0791 is offline
Old 25-11-2008, 12:44 AM   #14
Russell
Multiswitches are distribution amplifiers used in communal installations (and larger domestic installatiions). They require 4 inputs from a quattro lnb (NOT a quad as used in domestic installs) on a larger than normal dish. They are made in various versions with 6,8 and 12 outputs and also with4,5,8 and 9 inputs, the 8 and 9 input ones are for use with two lnbs for two different satellites, the 5 and 9 input ones are for adding terrestrial TV signals to the feeds to each flat. They can also be cascaded together to easily provide up to 48 outputs and even more with extra equipment. They are NOT a substitute for use in a flat for insufficient cables being available in a particular flat and are absolutely useless with only 1 input.
Domestic lnbs usually have 1,2,4 or 8 outputs and their use is preferable to using multiswitches unless more than 8 outputs are required.
If you have the problem of only one input in your flat you have only two choices fit your own dish (not usually acceptable to most landlords/ management committees) or to get the people responsible for your communal instalation to provide an extra output for your use and either another cable to your flat or to fit a stacker/destacker units (approx £100 plus fitting) to your existing cable providing it is of a good enough quality and short enough to allow twice the frequency band you have now. The stacker combines the two feeds into the one cable to your flat where the destacker unit splits the signal back into the two required feeds.
Old 21-05-2009, 7:58 PM   #15
I have found the multiswitch in communal cupboard just 5 metres from my front door. can i post photos so someone can identify it is indeed what i think it is... Thanks
tomreames is offline
Old 21-05-2009, 10:33 PM   #16
Thanks: Gave 12, Got 95
Hi if you are in an area i cover give me a bell and i will pop in and give you some advice
Last edited by Ian J; 28-05-2009 at 9:01 AM. Reason: Unnecessary hyperlink removed
Member 354643 is offline
Old 21-05-2009, 10:45 PM   #17
Originally Posted by 1Install.Com View Post
Hi if you are in an area i cover give me a bell and i will pop in and give you some advice www.1install.com
Looks like it area you cover, im in London E1. As I have all the equipment (I think) and it hopefully should be a matter of running the cabling into ceiling and about 5 to 10 metres to my flat how much do you ESTIMATE we'd be looking at? Can I email you photos of equipment Ive seen in the communal cupboard so you have an idea of whether I have what is needed etc... Thank you
Old 21-05-2009, 10:55 PM   #18
fernandez's Avatar
As I have all the equipment (I think) and it hopefully should be a matter of running the cabling into ceiling and about 5 to 10 metres ..
And, hopefully, as you indicated in a similar post in another thread you have the landlord's permission to alter/modify a communal system
Old 21-05-2009, 10:56 PM   #19
...also im going to speak to my building managers in the morning and if there is a problem doing this is one of these an option?: http://www.globalinvacom.com/products/pdfs/SCR_iss3.pdf as ive read you stock these.
does this just fit internally within my flat (i.e. not communal cupboard etc)?? thanks
Old 21-05-2009, 10:59 PM   #20
read my mind..
Old 21-05-2009, 10:59 PM   #21
Email mne the pics ill have a look no kieran@1install.com
Old 21-05-2009, 11:06 PM   #22
Here is some i have used theese in te past they are ok i like the one that sits on the floor looks like a white box dont think its on this website though but they are all about the same price, also you could consider an scr splitter from global invacom here is the details i have also installed these and they work really well providing you have the right sky box and it will allow you to have 2x sky+ from 1 cable feed they are really good for flats etc
feed, sky
Optimised for Firefox
AVForums.com is owned and operated by M2N Limited
Copyright © 2000-2010 M2N E. & O. E.
