Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
Latest AVForums Movie Reviews
Music Man, The Blu-ray ReviewUgly Truth, The Blu-ray ReviewEmpire Of The Ants - Original Motion Picture Soundtrack CD ReviewThe Toolbox Murders Blu-ray ReviewDungeons & Dragons: Wrath of the Dragon God Blu-ray Review
The Book of Eli - Original Motion Picture Soundtrack CD ReviewInvention of Lying, The Blu-ray ReviewSmokin' Aces 2: Assassins' Ball Blu-ray ReviewDorian Gray Blu-ray ReviewL'armée du crime Blu-ray Review
Thread Thread Starter Forum Replies Last Post
blu-ray fuzzy,- what could it be.. russ_e Home Entertainment PCs 8 03-07-2008 8:51 AM
LCD TV is fuzzy, DVD/VHS Cut off Chicago48 LCD and LED LCD Televisions 0 16-12-2007 4:20 PM
New HD Box fuzzy EPG lsba02853 Sky HD 2 17-11-2007 9:31 AM
Fuzzy Picture kensden Satellite TV 1 20-09-2003 12:08 PM
SVIDEO from NTL Pace to Panny 5 - fuzzy b&w?!? FaxFan2002 Virgin Media 6 21-07-2003 10:18 AM
Old 02-11-2008, 10:17 AM   #1 (permalink)
Thanks: Gave 3, Got 0
Fuzzy EPG from Sky+ on Panny
I need some advice.
I have a Sky+ Box connected to my Panasonic Viera th42pz80 using a Thor scart to scart cable.
I have noticed for a while that the EPG on the TV is fuzzy with what looks like a shadow of the letters overlapping and other EPG artifacts showing up and causing the screen to look, well, frankly quite annoying.
I have not messed with the settings on the TV or the Sky+ Box and I leave the aspect ratio on the TV on auto so the TV can select the best ratios itself. I have not changed colours or other settings. The TV is about a year old.
I hope someone can explain how I can improve the EPG and maybe even the picture. I am not sure but is this something to do with the resolutions and aspect ratios? I am a numpty on these matters and as usual require the expert help of you guys. Thanks.
atomicwaste12 is offline   Reply With Quote
Old 02-11-2008, 10:47 AM   #2 (permalink)
Thanks: Gave 6, Got 22
Re: Fuzzy EPG from Sky+ on Panny
On Sky remote, press Services, 4,1 and make sure the Scart Video Output is set to RGB and not PAL. Remember to save new settings if you change it.
Panasonic 50PV500, Sony STRD930, Toshiba RD-XS30, Pioneer DV565A, Sony SLV-E920, PS3 60Gb, Archos 605 Wifi 40Gb, Sky HD
Eyewhy is offline   Reply With Quote
Old 02-11-2008, 12:03 PM   #3 (permalink)
solidamber's Avatar
Thanks: Gave 32, Got 86
Also make sure your scart is plugged into the TV socket at the back of the Sky box, the VCR socket has no RGB output, and make sure the scart socket on the TV is RGB enabled, on my Panasonic only 2 of the 3 sockets are... if you use AV1 that would be fine.
solidamber is offline   Reply With Quote
Old 02-11-2008, 12:06 PM   #4 (permalink)
Rami Tupper's Avatar
Thanks: Gave 14, Got 23
some tvs will only accept an rgb signal if scart control is enabled on the sky box, in the services 4,1 menu.
LG 42PC1D, Sony STR-DG820, Toshiba SD44-HK, Blu-Ray & HD-DVD HTPC, SkyHD, Technomate 5200D, 1m motorised dish, Cambridge Audio SP105s, Harmony 885, Sony SA-W2500, Recieva based multiroom audio streaming, Waterproof 19" Bathroom LCD.
Rami Tupper is offline   Reply With Quote
Old 02-11-2008, 12:34 PM   #5 (permalink)
Thanks guys that has cleaned it up considerably, however there is still a slight shadow on the epg, but the other cr@p has gone and it is much sharper than before - and I also believe the image has improved overall. I could do with some help to get rid of the slight shadow. Any help on this would be gratefully accepted.
Old 02-11-2008, 12:44 PM   #6 (permalink)
fernandez's Avatar
Thanks: Gave 7, Got 740
Originally Posted by atomicwaste12 View Post
....however there is still a slight shadow on the epg, but the other cr@p has gone and it is much sharper than before - and I also believe the image has improved overall. I could do with some help to get rid of the slight shadow.
This may help with finding the ideal settings
Panasonic TH42PZ80 / TH42PZ80B Review: 42" Viera Plasma HDTV
If you've got a problem, someone else has had it before you
fernandez is online now   Reply With Quote
Old 02-11-2008, 7:10 PM   #7 (permalink)
Thanks: Gave 20, Got 32
Also make sure scart control is turned on , on the Sky+box
deanos is offline   Reply With Quote
Old 03-11-2008, 11:12 AM   #8 (permalink)
Jimmo 32's Avatar
Thanks: Gave 1, Got 22
Also,if its a new tv(or not),the out of the box settings are rubbish,make sure you turn off all digital settings/noise reduction etc,as these setting tend to make the picture worse rather than make it better.
Jimmo 32 is offline   Reply With Quote
Old 04-11-2008, 3:01 PM   #9 (permalink)
solidamber's Avatar
And make sure the picture setting is not on the default Dynamic setting wich is overbright to make it "pop" instore
Old 04-11-2008, 6:05 PM   #10 (permalink)
alan1572's Avatar
Thanks: Gave 3, Got 30
make sure you make snacks...it sounds like you could be there a while
alan1572 is offline   Reply With Quote
epg, fuzzy, panny, sky
Copyright © 2000-2010 M2N E. & O. E.
