Remote battery life
Old 20-10-2008, 12:23 PM   #1
2,115, Level: 10
Points: 2,115, Level: 10 Points: 2,115, Level: 10 Points: 2,115, Level: 10
Thanks: Gave 1, Got 0
Remote battery life
My sky plus remote eats batteries at the rate of 2 every 6 days Does anyone else use them at this rate I have tried sky telephone advice line but can never get through.
Old 20-10-2008, 12:55 PM   #2
14,080, Level: 28
Points: 14,080, Level: 28 Points: 14,080, Level: 28 Points: 14,080, Level: 28
Activity: 42.6%
Activity: 42.6% Activity: 42.6% Activity: 42.6%
Thanks: Gave 84, Got 576
Re: Remote battery life
Are you using "cheapo" batteries? (Read latest Which report)
Good alkalines should last 12 months or so.
Neil
Old 20-10-2008, 4:52 PM   #3
17,819, Level: 32
Points: 17,819, Level: 32 Points: 17,819, Level: 32 Points: 17,819, Level: 32
Activity: 17.9%
Activity: 17.9% Activity: 17.9% Activity: 17.9%
Thanks: Gave 11, Got 917
Mine last at least 9 months although my father (an inveterate button presser) manages to get through a set in 3 to 4 months. Alkaline batteries - Tescos, Sainsbury's or Duracell no difference betwwen them.
Old 20-10-2008, 5:09 PM   #4
12,546, Level: 26
Points: 12,546, Level: 26 Points: 12,546, Level: 26 Points: 12,546, Level: 26
Activity: 41.7%
Activity: 41.7% Activity: 41.7% Activity: 41.7%
Thanks: Gave 217, Got 317
You seem to have a faulty remote, perhaps with one of the buttons stuck down (although if it works, this is unlikely).
You can get a new remote for about £15 (even less on eBay).
Much cheaper than new batteries every week!
Old 20-10-2008, 5:29 PM   #5
2,863, Level: 12
Points: 2,863, Level: 12 Points: 2,863, Level: 12 Points: 2,863, Level: 12
Thanks: Gave 2, Got 6
Got to be the remote. Even new cheap batteries would last far longer than 6 days.
silverhorse (20-10-2008)
Old 21-10-2008, 6:05 PM   #6
Illustrious Member
JohnG's Avatar
41,473, Level: 49
Points: 41,473, Level: 49 Points: 41,473, Level: 49 Points: 41,473, Level: 49
Activity: 13.5%
Activity: 13.5% Activity: 13.5% Activity: 13.5%
Thanks: Gave 2,200, Got 1,080
I've noticed that rechargeable batteries only last a couple of weeks in mine, but I assume that's because they are rechargeables ?
