Way to improve RF signal?
Old 19-10-2008, 5:34 PM   #1
sad_muso's Avatar
3,082, Level: 13
Points: 3,082, Level: 13 Points: 3,082, Level: 13 Points: 3,082, Level: 13
Thanks: Gave 1, Got 0
My setup is as follows:
Sky+ box > RF2 out > 25m coax cable > magic eye > aerial lead into TV
Everything is working fine but the picture is a bit 'wobbly' - is there a way to improve this? I managed to get it almost perfect last night by twiddling the coax leads on the magic eye end - does this mean I've done a bad job at wiring the coax plug? I just want to stop the wobblyness!
Thanks!
Old 19-10-2008, 5:46 PM   #2
15,354, Level: 29
Points: 15,354, Level: 29 Points: 15,354, Level: 29 Points: 15,354, Level: 29
Thanks: Gave 18, Got 1,045
Re: Way to improve RF signal?
You've already got a thread going here on the same subject
RF2 Output from Sky+ Box 'wobbly?'
but, yes, the connections sound poor and there's also to be taken into account the 25M cable.
If this the thin white type sold in places like Argos/Asda etc. then yes, I think, some signal loss may occur.
Make sure that the RF channel that the Sky box is set to is not near a channel used by terrestrial broadcasts in your area and this shows you how to fit co-ax plugs (if you're not sure)
How to fit TV plugs to coaxial cable
