Sky+ TV Planner
Old 18-10-2008, 11:24 AM   #1
Treadmore
Posts: n/a
Sky+ TV Planner
Hi there - just purchased a Sky+ box and all works well but is there any way that I can delete channels from the TV Guide that I don't subscribe to? I've removed the Adult Channels but there are loads of others that I don't subscribe to and they really clutter up the tv guide - pretty annoying! Any help gratefully received.
Many thanks in advance.
Old 18-10-2008, 11:33 AM   #2
Boon72's Avatar
3,962, Level: 14
Points: 3,962, Level: 14 Points: 3,962, Level: 14 Points: 3,962, Level: 14
Thanks: Gave 2, Got 105
Re: Sky+ TV Planner
you can set up favourites (50) then when you go into the tv guide press the blue button to see only the ones you picked as favs.
Old 18-10-2008, 6:45 PM   #3
Treadmore
Posts: n/a
Re: Sky+ TV Planner
Thanks Boon - I didn't think of that (doh!).
