AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 07-08-2008, 1:11 PM   #1 (permalink)
Thanks: Gave 5, Got 1
Record On Second Sky + Box
I have a Sky HD box in my lounge, and am considering inserting my old Sky + box upstairs in the bedroom as a free view box. Just a quick question - with no card in the box (ie a FTA only receiver) can I still use the Sky + functionality (I have a CT63 cable already ready from the LNB) for free?
jimsss is offline
Old 07-08-2008, 1:17 PM   #2 (permalink)
Thanks: Gave 13, Got 431
Re: Record On Second Sky + Box
No. You'll have to take out multiroom (or at least pay Sky £10 per month for Sky+ functionality without a Sky TV subscription) to enable Sky+ functionality on the second box.
Broadz is offline
Old 07-08-2008, 1:20 PM   #3 (permalink)
Thanks: Gave 3, Got 70
...can I still use the Sky + functionality....
What "functionality" are you looking for?
(If you have the cable hooked up to the LNB, in your bedroom, have you actually tried it?)
Neil
Stevenage Neil is offline
Old 07-08-2008, 1:23 PM   #4 (permalink)
Originally Posted by Broadz View Post
...... pay Sky £10 per month for Sky+ functionality without a Sky TV subscription..
I "thought" that was dropped months ago, but am willing to be proved wrong.
Neil
Old 07-08-2008, 1:27 PM   #5 (permalink)
Nope, still exists.
Broadz is offline
Old 07-08-2008, 1:43 PM   #6 (permalink)
Nope, still exists.
Ta- you live and learn ..
Old 07-08-2008, 1:46 PM   #7 (permalink)
Which is why, if the OP does want to be able to record on his second box, he would do better taking out multiroom and getting the same channels on his second box (plus the ability to record them) for the same cost as being able to record just the free channels (£10 per month either way). The only downside is he will have to connect both boxes to the same phoneline (and he would be taking out a new 12 month subscription for the multiroom account).
Broadz is offline
Old 08-08-2008, 11:17 AM   #8 (permalink)
Thanks: Gave 4, Got 0
I'm thinking of doing the same sort of thing. We have Sky + downstairs and
a standard box upstairs with multi room subscription. I was thinking of buying a Sky HD box on its own to replace the standard box upstairs and just get the subscription channels and free to air HD channels (BBC HD etc). I obviously only have one wire from the dish upstairs. Can I still use the Sky + functions but only record the channel that is currently on. I'm not too bothered about being able to record two channels at once because most of the time I set thing to record is when i'm out so I can just leave it on the right channel.
This would be easier to do because I can just buy the box and hook it straight up withour having to get a second wire installed.
Anyone know whether this is OK to do?
Peter
Big P is offline
Old 08-08-2008, 11:34 AM   #9 (permalink)
Skytech's Avatar
Thanks: Gave 23, Got 131
Yeah you can do that no problem. You'll need to let Sky know when you change the boxes but make it clear you DO NOT want the £10 HD mix.
Core 2 Duo E8400 3Ghz, Gigabyte P35C DS3R, 512Mb 8800GT, 2x1GB Corsair 800Mhz XMS2, 22" 1680x1050 TFT.
Skytech is online now
Big P (08-08-2008)
box, record, sky
Refbacks are On
Thread Thread Starter Forum Replies Last Post
looking for perfect box - record 2 freeview + dvd record nigelrmtaylor PVRs and VCRs 25 29-12-2007 5:26 PM
How to make Media Centre record only a SINGLE instance of a series record schedule gphillips Windows Media Center Edition MCE 13 02-02-2007 11:37 AM
Timer record/ Purpose? does it actually activate your video box to record? Eye2007 Freeview 1 31-07-2006 6:08 AM
how can you record onto dvd from pvr phetttt PVRs and VCRs 2 17-12-2005 2:32 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
