AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 06-08-2008, 9:50 AM   #1 (permalink)
Thanks: Gave 7, Got 0
Cool No Sky RF.
I have just installed a Sky + box to replace my old Sky box. With the original one I had the RF output connected to a 3-way amp and this was then co-axed through to the other rooms - this worked perfectly. Having got the Sky + box set up and working I cant seen to find the Sky RF signal at all. The TV Ariel signal is being distributed as before but try as I might I cant locate any Sky + RF at all.
Can anyone point me in the right direction or have I got a fault Sky + box.
Many Thanks.
glenvine is offline
Old 06-08-2008, 10:07 AM   #2 (permalink)
Thanks: Gave 3, Got 70
Re: No Sky RF.
I strongly suspect your new Sky box has a different RF channel selected. Try re-tuning your TV's.
Neil
Stevenage Neil is offline
glenvine (06-08-2008)
Old 06-08-2008, 10:09 AM   #3 (permalink)
fernandez's Avatar
Thanks: Gave 3, Got 333
Re: No Sky RF.
Have you checked the tuning on the TV set(s) connected to RF2?
The default setting on receivers is Channel 68 and your previous receiver *may* have been set to another channel.
So, either retune the TVs or select another RF output channel on the Sky box
If you've got a problem, someone else has had it before you
fernandez is online now
Old 06-08-2008, 10:21 AM   #4 (permalink)
Re: No Sky RF.
Originally Posted by fernandez View Post
...or select another RF output channel on the Sky box
Services/System Set Up/0, 1/Select/RF Outlets
Old 06-08-2008, 11:02 AM   #5 (permalink)
Thanks: Gave 13, Got 304
Re: No Sky RF.
Connect via Scart.
Press [services] 401 [select] 4
Set the RF output channel to the number you had on the old box.
Set the RF outlet power to ON.
Save the settings.
Yorkshire men are blunt to the point of seeming rude. But inwardly they smile a lot!
SamRadford is offline
Old 06-08-2008, 11:24 AM   #6 (permalink)
Thumbs down Re: No Sky RF.
I really appreciate the advice - most of which I had already tried - but thanks to you all anyway.
Sadly none of the TV's appear to be receiving the Sky RF signal on any channel. I have tried a full channel search on each one but to no avail. Any other ideas please?
glenvine is offline
Old 06-08-2008, 11:48 AM   #7 (permalink)
Thanks: Gave 13, Got 431
Re: No Sky RF.
There are two RF outs on a Sky box. Try the other one and see if this works. If it does you have a box with only one working RF - so return it.
Broadz is offline
Old 06-08-2008, 7:53 PM   #8 (permalink)
Thumbs up Re: No Sky RF.
Thanks to everyone who posted all the very useful info to my problem. I took another look at the spaghetti at the back of my TV system - pulled out all the RF leads and re-installed. Swapped the RF output channel on the sky box and re-tuned the other TV's to the new Chanl number - BINGO Everything appears to be hunky-dory now.
Thanks posted to everyone.
glenvine is offline
rf signal, sky, sky +
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
