AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 05-08-2008, 12:55 PM   #1 (permalink)
Quick Sky+ question
I have just moved into a new house which had standard Sky installed.
It currently looks like the old occupants have had an aerial lead intstalled from the back of the tv/Sky through the external wall and run back in through the wall and into a bedroom.
Im guessing they used a splitter to allow the signal to go to two tv's.... My question is can this lead be used in the same manor with Sky+ ???
Im getting Sky+ installed on Saturday and wondered if this would work and if I would need any other items to enable me to watch the signal in two rooms (same picture obviously on both sets as only one Sky+ box)
On a seperate note does anyone know the quality of the Sky+ remote... Will it past through walls or not???
extrememonkey is offline
Old 05-08-2008, 3:00 PM   #2 (permalink)
Re: Quick Sky+ question
Originally Posted by SamRadford View Post
Only if you throw it extremely hard!
(I have no idea what you mean.)
Ha Ha Ha.... very funny!!!
What I meant to say was - Will the IR pass through walls/floors at all so I could control the Sky+ box from a room directly above the box???
Old 05-08-2008, 3:07 PM   #3 (permalink)
Skytech's Avatar
Thanks: Gave 23, Got 135
no, IR is line of sight only, hence you can cover the front of the RCu with your hand. you need a TV link device to allow control of the box from another room or a wireless AV sender system.
Core 2 Duo E8400 3Ghz, Gigabyte P35C DS3R, 512Mb 8800GT, 2x1GB Corsair 800Mhz XMS2, 22" 1680x1050 TFT.
Skytech is offline
question, quick, sky
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Quick question needing a quick reply, Humax tuning. Cornishcelt PVRs and VCRs 2 16-09-2007 3:45 PM
Quick question quick answer please :) nutty82uk LCD Televisions 3 06-06-2007 2:41 PM
Quick question (quick answer please) RHCP Integrated AV Amplifiers and Receivers 5 12-08-2006 6:01 PM
EPISODE III - Quick Question that needs a quick answer tha-dizzle Movies and The Cinema 10 24-05-2005 12:21 PM
Quick Philips question - needing a quick answer!!! prycop CRT Televisions 0 26-11-2003 7:32 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
