AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 03-08-2008, 8:37 PM   #1 (permalink)
Thanks: Gave 40, Got 38
Sky installation questions
Hello,
I am moving to a new flat which is not in a cable area (I am with Virgin now, I don't like them but not having to have a dish is a bonus when renting)
I have a couple of questions I was hoping people can answer.
1. The new flat doesn't have a dish as far as I am aware, if I get permission to have one installed, I am slightly concerned that due to buildings to the south, I will not get a good enough signal. How can I check this? What if I order and they try to install and it doesn't work, do I have to pay for their attempt at installing it?
2. What needs to come into the house? I imagine a single cable comes from the dish, but I also am guessing that this involved drilling holes into walls etc. Is this the case? If so, do the Sky engineers run the cable into the house, drill all the necessary holes etc?
3. Who owns the dish once it is installed? Would it be beneficial for my landlord as it would always be there and could be used as a selling point for her in the future? Or is is simply drilling holes and making a mess for no reason?
I think that is it for now. Thanks in advance for any help.
www.ScarySquirrel.co.uk - DeviantArt - XBox 360 GT - ScarySquirrelUK - PSN ID - ScarySquirrel
ScarySquirrel is online now
Old 03-08-2008, 9:59 PM   #2 (permalink)
Skytech's Avatar
Thanks: Gave 23, Got 135
Re: Sky installation questions
Sky will do just about everything, holes, dish up, everything to get your sky. How close are the buildings? The dish, theoretically becomes the property of the account holder, so, strictly speaking you could take it with you.
Core 2 Duo E8400 3Ghz, Gigabyte P35C DS3R, 512Mb 8800GT, 2x1GB Corsair 800Mhz XMS2, 22" 1680x1050 TFT.
Skytech is online now
ScarySquirrel (04-08-2008)
Old 04-08-2008, 7:43 AM   #3 (permalink)
Thanks for your answer.
I need to go and scope it all out a bit again and see if it would be viable. It would need to go on the front of the house so not sure.
Can anyone answer my question about what money I lose if Sky cannot get a good enough signal? Can they find this out BEFORE drilling holes and everything?
Old 04-08-2008, 4:52 PM   #4 (permalink)
Skytech's Avatar
yes, he can check you're able to get a signal before he does any drilling.
Old 05-08-2008, 2:38 PM   #5 (permalink)
Thanks: Gave 13, Got 304
No, if there's the slightest doubt, the installer will simply walk away from the job. They don't check "borderline", even though there may be no problem at all. They simply aren't allocated enough time. Make sure there's a clear view at about a 20 degree upward angle on a bearing of about 30 degrees east of compass south.
Yorkshire men are blunt to the point of seeming rude. But inwardly they smile a lot!
SamRadford is offline
installation, questions, sky, sky dish installation
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Installation questions. Upholder DLP, LCD and D-ILA Projectors 3 15-10-2007 4:56 PM
Installation questions Mafro Sky HD 2 24-02-2007 9:14 PM
Sky HD installation questions... PlasmaVirgin Sky HD 2 20-11-2006 6:21 PM
SKY+ after installation questions rbecking Sky and Sky+ 2 07-10-2003 9:08 PM
Sky Installation Questions Mr_P Sky and Sky+ 4 08-07-2002 1:15 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
