AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 02-08-2008, 5:48 PM   #1 (permalink)
Thanks: Gave 2, Got 0
How to replace my Sky box with Sky + box
I have aquired a Sky+ box and card.
I have Sky+ downstairs and standard Sky multiroom with sports package upstairs.
What do I need to do exactly to get the Sky+ box to work in place of the upstairs box? Will Sky want any more cash off me?
Bobred is offline
Old 02-08-2008, 11:12 PM   #2 (permalink)
Re: How to replace my Sky box with Sky + box
I've done a fair bit of reading up now so I may be sorted.
I have a quad LNB on the mini dish so take it I just need to connect new cable from the LNB to the Sky+ box aswell as the cable that is already in place.
Then.........put in my Sky card and ring Sky in order that they can 'pair' it to the Sky + box.
That's it ?
Bobred is offline
Old 02-08-2008, 11:54 PM   #3 (permalink)
Thanks: Gave 3, Got 70
That's it ?
Yes
Stevenage Neil is offline
Old 03-08-2008, 9:38 AM   #4 (permalink)
Thanks: Gave 25, Got 19
In the meantime you can run the Sky+ off a single feed, albeit with limited functionality (can't dual record or record one watch another). There's a number of threads here about setting dummy recordings to do this. To avoid drilling another hole in the wall, you may want to replace the single cable with shotgun cable. www.satcure.co.uk have a number of technical guides to assist.
jrisch is offline
box, replace, sky
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Help! Sanyo Z4 - said to replace lamp, New one put in but still says to replace lamp thudspud DLP, LCD and D-ILA Projectors 26 22-03-2008 10:53 PM
Replace CDP or buy DAC or (?) PaulBoy Hi Fi Systems and Separates 7 29-11-2005 9:29 AM
Is it possible to replace a US PSU with a UK one? Tyler Durden Integrated AV Amplifiers and Receivers 4 06-05-2005 11:40 PM
B&W ASW500 . To replace or not to replace this is the question. hinesle Subwoofers 1 27-01-2005 3:26 PM
Sky to replace Sky Travel on Freeview and replace it with "Free version of Sky One" PhilipVass Sky and Sky+ 5 03-10-2003 12:47 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
