Signal Problems
Old 03-02-2008, 9:57 PM   #1
1,961, Level: 10
Points: 1,961, Level: 10 Points: 1,961, Level: 10 Points: 1,961, Level: 10
Thanks: Gave 5, Got 2
Signal Problems
I am having problems with some of my sky channels on my sky + box particularly Sports 1,3 and News and hardly get Sky Sports 2 at all and have retuned to an other channel for that one. Also Paramount Comedy 2 struggles but both its 1 and + 1 channels are ok.
Now this is happening most commonly in the morning and evenings and during the day I can get a patchy signal for some of them.
Now having researched this problem its seems it may be linked to a need to replace the power supply. Does that seem to be the answer? or is it a dish alignment issue?
Old 03-02-2008, 11:42 PM   #2
Tesla's Avatar
6,657, Level: 19
Points: 6,657, Level: 19 Points: 6,657, Level: 19 Points: 6,657, Level: 19
Thanks: Gave 21, Got 35
Re: Signal Problems
Sounds more like LNB fault to me, do you have anything else connected to the LNB or any spare Sky boxes you can test it with?
