AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 29-06-2007, 1:25 PM   #1 (permalink)
bobbymax's Avatar
Thanks: Gave 2, Got 2
PVR & Sky?
Sorry if this is a dumb question.
Can a my own PVR be used in junction with the Sky standard box?
Bob.
bobbymax is offline
Old 29-06-2007, 2:37 PM   #2 (permalink)
Thanks: Gave 9, Got 61
Re: PVR & Sky?
Bob.
Depends on the model. If it's a Freeview Pvr, chances are no.
simon1 is offline
Old 29-06-2007, 3:19 PM   #3 (permalink)
Thanks: Gave 71, Got 11
Re: PVR & Sky?
Well yes the PVR will work with Sky not in true PVR fashion. It will work just like a VCR would, as in you have the digibox on the correct channel and use timers on the PVR.
Cheers,
Raj
___________________
LE40M87BDX|Sky+ SD|Sony STR-DA1200ES|Monitor Audio BR2s|Denon DVD-1930|Soundstyle Z2
rajivkotecha is offline
Old 29-06-2007, 4:22 PM   #4 (permalink)
Thanks: Gave 0, Got 299
Re: PVR & Sky?
Unless the PVR has an analogue input (scart or s-video) OR an analogue terrestrial TV tuner it will NOT record from Sky.
In general most DVD/HDD recorders will record but virtually all Freeview PVRs will not.
Make and model of PVR would actually help to answer this question otherwise everyone is just guessing.
Sky+ Pace PVR1,Sky+ Amstrad PVR3Sky Pace 2500, Fortec Star Ultra Diamond, Technomate TM9100, Fortec Star 5100 CI Diamond + Dragon CAM, Pace Twin view, Nokkia 9850 On Digital Box, Force DMaster 1122s, 2.8 ghz P4, Skystar2 PCI card, Artec USB Freeview box
davemurgatroyd2 is online now
Old 29-06-2007, 6:04 PM   #5 (permalink)
bobbymax's Avatar
Re: PVR & Sky?
Thanks for the replys guys.
The PVR I'm talking about is the Topfield TF5800PVR.
I'm being a bit of a tight a**e , want to avoid paying the extra £10 mth for their set (Sky +).
bobbymax is offline
Old 29-06-2007, 9:01 PM   #6 (permalink)
Thanks: Gave 0, Got 8
Re: PVR & Sky?
From July you no longer have to pay £10 a month if you don't have the necessary number of premium channels, so I'd say get yourself a Sky+ (naturally I'm assuming you do subscribe/plan to subscribe to some of the Sky mixes as I think if you don't subscribe to anything and just get the free to air stuff you still have to pay Sky the £10 a month)
Toshiba 28HD46, Yamaha RX-V2095, Pace Sky+, Pioneer 656A, JVC HR-S6722, Sony MDS-JB980, Mission 704 front, 70c2 centre, 702 rear, Logitech Harmony 885, Philips Pronto RU940, X-Box
cerebros is offline
Old 30-06-2007, 7:32 PM   #7 (permalink)
bobbymax's Avatar
Re: PVR & Sky?
Thanks for reply, will wait and see what the next offers are.
bobbymax is offline
Old 30-06-2007, 9:23 PM   #8 (permalink)
Super Moderator
Thanks: Gave 188, Got 711
Re: PVR & Sky?
Topfield TF5800 is a Freeview PVR and that's all you can use it for. It needs feeding with a proper UHF aerial suitable for reception conditions wherever you are.
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline
Old 30-06-2007, 10:33 PM   #9 (permalink)
bobbymax's Avatar
Re: PVR & Sky?
Ok, thanks.
So, does that mean I will be able to just record the Freeview channels with the Toppy/standard Sky box, or can't I use the Toppy at all? (Sorry, still getting my head around it all).
bobbymax is offline
Old 01-07-2007, 8:18 AM   #10 (permalink)
Super Moderator
Re: PVR & Sky?
If you have a TF5800 and a suitable aerial then you can use the TF5800 to record Freeview only. If you have no, or an inadequate aerial, then the TF5800 is useless. If you have no, or a poor Freeview signal where you are, it is useless.
The Sky box plays no part in this. It is not used to provide signal for recordings. You can, of course, use a Sky box to watch satellite TV live, while the TF5800 is recording Freeview from your aerial.
Nigel
LV426 is offline
Old 01-07-2007, 12:33 PM   #11 (permalink)
bobbymax's Avatar
Re: PVR & Sky?
Thanks again, learning all the time.
bobbymax is offline
Old 01-07-2007, 9:44 PM   #12 (permalink)
Thanks: Gave 11, Got 29
Re: PVR & Sky?
well the Topfield TF5800 does have 2 scarts(TV & VCR), have you tried recording a signal on it using the VCR one?? (using an old VCR, game or camera)
If this works, you can of course do the same with the output of a sky box, as long as it is not 'protected' ie a premium channel...
don't take me wrong, I'm Happy to pass on knowledge, to stop the confusion and FUD!!0
when SwitchOff??- switching!! USB, 'net, wireless expandable DVDR?? - Media PC!! DVD manuals! -bigger hardrive??-divx- low quality, bad frame-rate Digital Video..
foneman is offline
Old 01-07-2007, 10:25 PM   #13 (permalink)
Re: PVR & Sky?
NO NO NO NO NO
Several posters have already confirmed you can not record from any external sources. Full stop.
The Topfield (like many other freeview pvrs) does not contain the necessary encoders to covert any other inputs for recording onto the HDD.
simon1 is offline
Old 01-07-2007, 11:29 PM   #14 (permalink)
Re: PVR & Sky?
relaaaaax, man....
a simple 'I have tried, does not work' would be ok.. instead of blindly believing..
and no, too many are saying 'it cant decode sky' and not 'the scart input does not record' .. no mention of scarts at all, actually...
foneman is offline
Old 02-07-2007, 7:18 AM   #15 (permalink)
Super Moderator
Re: PVR & Sky?
OK For the absolute avoidance of any doubt......
No current Freeview PVR can record from external sources. And no models have been announced that will do so. And they cannot be modified to do so.
These machines do not contain any electronics to encode an external signal into the MPEG2 format used on their Hard Disc. They can only receive and record from a digital terrestrial broadcast.
Those that do have a second SCART (or other) socket as an input, have it for loopthrough purposes only; they will pass the signal through from one socket to the other when they are turned off.
Only DVD recorders (with or without Hard Disc) can record from external sources.
Nigel
LV426 is offline
pvr, sky
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
