AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 28-06-2007, 10:22 PM   #1 (permalink)
Programme has been recorded on Sky+ but wont playback
I have one particular programme in my planner that has been recorded but I can't get it to play. Can anyone help please?
All other programmes in the planner will play. The one that won't gets as far as the screen where you select the start position but then the select/play/back up buttons stop working. To get out of that screen I have to press either the TV Guide or Sky button.
70s_kid is offline
Old 28-06-2007, 11:47 PM   #2 (permalink)
Thanks: Gave 9, Got 61
Re: Programme has been recorded on Sky+ but wont playback
This has happened to me on three separate occasions in the last 6 or 7 months. I just put it down to a software glitch.
simon1 is offline
Old 29-06-2007, 8:05 AM   #3 (permalink)
OK, so you just have to forget about watching it and delete it? That's really annoying! I take it it deletes without any trouble then?
70s_kid is offline
Old 29-06-2007, 10:03 AM   #4 (permalink)
Afraid so.
Should delete OK.
simon1 is offline
Old 29-06-2007, 12:58 PM   #5 (permalink)
Thanks: Gave 0, Got 299
This is down to corruption of either the planner entry or the recording itself. These can both often be cured by a Sky+ planner rebuild - "Services" "System setup" "0" "1" "Select" takes you to the hidden installers setup menu. The planner rebuild will not usually affect good recordings but will sometimes repair corrupted ones otherwise it marks them as failed
Sky+ Pace PVR1,Sky+ Amstrad PVR3Sky Pace 2500, Fortec Star Ultra Diamond, Technomate TM9100, Fortec Star 5100 CI Diamond + Dragon CAM, Pace Twin view, Nokkia 9850 On Digital Box, Force DMaster 1122s, 2.8 ghz P4, Skystar2 PCI card, Artec USB Freeview box
davemurgatroyd2 is online now
simon1 (29-06-2007)
Old 29-06-2007, 1:39 PM   #6 (permalink)
Thanks for that advice. I never thought of using the planner rebuild option. I'll try that next time.
simon1 is offline
Old 30-06-2007, 8:57 AM   #7 (permalink)
Tried the planner rebuild, it made no difference. Thanks anyway.
Any more suggestions folks before I delete it?
70s_kid is offline
Old 30-06-2007, 6:01 PM   #8 (permalink)
If this was a movie or a channel you no longer subscribe too then you won't be able to view it. real nice of sky 4 that one.
Summermoon is offline
Old 01-07-2007, 1:19 PM   #9 (permalink)
But the reverse is also true - you can record channels you do not subscribe to and upgrade your subscription at a later date (for a month or so) and then watch them. A current subscription is required to watch any programme or recording.
playback, programme, recorded, sky
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
