AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 28-06-2007, 7:09 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Thomson box problem ?
I've got a Thomson Sky+ box (Model 127k148, SW 1.31 B03, EPG 5.02.f)) I have had a problem with signal quality and replaced the LNB and checked the alignment. The signal quality is ok (if a little fragile - I have problems with trees) after fiddling but after a while I lose lock on both inputs. If I remove the power and then reboot the box it then locks ok.
Has anyone else had this problem and is there a potential fault with the box or is it normal to have to reboot it if it loses lock ?
Cheers,
Richard
Worthywow is offline
Old 29-06-2007, 4:44 PM   #2 (permalink)
Thanks: Gave 13, Got 304
Re: Thomson box problem ?
You don't mention the model number or age of your Digibox. If it's more than a year old, the power supply capacitors may be failing - in time-honoured Grundig fashion!
Yorkshire men are blunt to the point of seeming rude. But inwardly they smile a lot!
SamRadford is offline
Old 01-07-2007, 6:02 AM   #3 (permalink)
Chris4Koi's Avatar
Thanks: Gave 28, Got 9
We had major problems with trees....
During the winter time, picture was, well... OK I guess.... but come spring when all the trees were in leaf.... the signal would be very fragile with less than 50% at best....
So had to have a mast installed to mount higher to go over the tops of the trees...... so now have at leat 75% on both strength and quality.... just the rain that craps out the picture now.... and its supposed to be summer time in June..... That's good old blighty weather for you....
ATB
Chris
Pioneer 507 XD Display: Pioneer 696DVD: Pioneer VSXAX2AS-s AV Amp: Speakers Monitor Audio Bi-Amped RS8's, RSW12 Sub, Bi wired RSLCR centre and RSFX rears, Silver Anniversary XT cables: now got Sky HD and SKY+...
Chris4Koi is offline
Old 01-07-2007, 10:50 AM   #4 (permalink)
Papua's Avatar
Thanks: Gave 13, Got 26
Hi, I posted a similar thing a week ago. I have now moved the dish up a couple of feet. The pole used to point downwards so I just rotated it and put the dish at the top. With a cheapy meter from ebay it's surprising how easy it is to get a good signal.
I don't know about the thomson sky+ boxes, but if they are like the HD boxes from thomson then your problem is exactly the same as the HD box. If you have a torrential downpour or loose the signal a reboot is the only way out even though the system shows a good signal and locked. Poor design thats unable to recover unfortunately.
Papua is offline
box, problem, thomson
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
