AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 27-06-2007, 9:26 AM   #1 (permalink)
lonestar's Avatar
Thanks: Gave 12, Got 2
remote record with two sky+ receivers
hello all,
my sky setup changed from sky+ with sky multiroom, to skyhd with sky+ multiroom.
i had remote recording setup from sky's website to push out a record request to my sky+, what i'd like to know is, is it possible to register my skyhd receiver for remote record as well, and if it is possible how do i go about doing it?
many thanks.
If you shoot me in a dream, you better wake up and apologise.
lonestar is offline
Old 27-06-2007, 2:10 PM   #2 (permalink)
Thanks: Gave 71, Got 11
Re: remote record with two sky+ receivers
Yes, i believe that you have to to go, on your HD box, to interactive, Sky Customer Servies, Remote Record, Login and register from there.
Though i don't know hwo you differentiate between the 2 boxes when using RR from the PC, i would assume that either a particular user(name) was tied to a particulat box, or that when you pressed RR you had to choose the Box.
Cheers,
Raj
___________________
LE40M87BDX|Sky+ SD|Sony STR-DA1200ES|Monitor Audio BR2s|Denon DVD-1930|Soundstyle Z2
rajivkotecha is offline
receivers, record, remote, sky
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
