AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 26-06-2007, 7:58 PM   #1 (permalink)
Papua's Avatar
Thanks: Gave 13, Got 26
Trees Causing A Problem?
A mate with sky+ started losing his signal badly a couple of weeks ago when we had a lot of rain. I had a quick look and the signal strength was about 50% and there was no signal quality. We changed the dish from a 40cm to 60cm, changed both cables to the sky+ box and put in a new quad lnb.
The signal strength has now increased 70% and the quality to 25% on some channels but zero on others. A lot of the channels break up. BBC2 & Sky Movies are not watchable along with some others.
We changed to box to a HD box and Sky movies HD1 and HD2 and Sky One HD can't be received yet the other channels are there.
There are a number of trees across the road from his house that are probably 25-30 feet high and this dish is able 10ft high on his house. Would the trees cause this sort of signal blockage? It seems surprising that we can get 70% signal strength yet no quality at all. I have now suggested getting a local installer in but he thinks that if it is the trees then there is nothing that he can do as they belong to a company 120 miles away that rents the ground to a group of shops.
Papua is offline
Old 26-06-2007, 8:25 PM   #2 (permalink)
sbowler's Avatar
Thanks: Gave 122, Got 436
Re: Trees Causing A Problem?
could he mount the dish higher up on the house, even on the chimney?
My flickr Pentax K10D Sigma 10-20/24-135/70-210/Pentax 50mm f1.4/Sigma 24-70mm DG-EX
MyA/V
"Chance favors the prepared mind"
sbowler is offline
Old 26-06-2007, 8:49 PM   #3 (permalink)
Papua's Avatar
Hi, its on a ground floor flat so he can't move it up more than a couple of feet.
Do trees cause a loss of quality but the signal strength still remains high?
Papua is offline
Old 27-06-2007, 8:06 AM   #4 (permalink)
961
Thanks: Gave 33, Got 81
Yes, trees cause the problem you describe, especially when in full leaf during the summer
One answer is to negotiate with the building owner for permission to put a dish on the roof
However, the fact that the problem started after heavy rain leads to the conclusion that there may be a waterproofing problem.Ensure that the connections to the lnb are weatherproof, and since you now have a 70% signal on some channels ensure the dish/lnb alignment is spot on
961 is offline
Papua (27-06-2007)
Old 27-06-2007, 8:55 AM   #5 (permalink)
Thanks: Gave 1, Got 2
I had this very same problem last week, we had terrible rain and thunder storms (monday/tuesday), all of a sudden we went from having fantastic signal strength (nearly 100%) and quality (about 75%) to next to nothing, signal strength 75%, but signal quality 25%.
Put it down to the thunder storm having fried my lmb (bugger i thought, costly sky repair bill!!). Spoke to a mate who works in the world of SKY/Ariels etc and he said the the thunder storm should not have fried the lmb (although not impossible) and did we have trees nearby.
To cut a long story short our next door neighbour has a tree which is pretty much in line with our sky dish so when the rain stopped i nipped out and cut back the branches (it's no great oak or anything) so that the line of the dish was better and hey presto we now have 100% signal strength back and 75-80% signal quality. Now this could be coinsidence (sp?) as i can't understand why all of a sudden it went but i'm praying it was the tree. Will have to keep an eye on things.
monkeyboykev is offline
Papua (27-06-2007)
Old 27-06-2007, 10:59 AM   #6 (permalink)
Thanks: Gave 13, Got 304
Wet leaves disperse the satellite signals in such a way that some frequencies may get through but others won't. They act like a diffraction grating.
Yorkshire men are blunt to the point of seeming rude. But inwardly they smile a lot!
SamRadford is offline
Papua (27-06-2007)
Old 27-06-2007, 7:29 PM   #7 (permalink)
Papua's Avatar
Thanks for your replies, I sort of thought it would be the trees causing the problem. I just found it strange that the signal strength was high but no quality.
I've found on the sky+ box that if you set two recordings going on channels that you are having problems with and then look at the signal strength / quality meters you get the information directly from the faulty channels rather than the default transponder. I know you can change the default transponder in the installation menu but that it a bit of playing around.
Papua is offline
causing, problem, trees
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
