AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 26-06-2007, 9:59 AM   #1 (permalink)
Thanks: Gave 2, Got 0
Sky Digibox Best TV Connection?
All,
I am moving to multiroom and in the bedroom want to connect a Sky Digibox to a Samsung LE-32R87BD (has HDMI,Scart, RGB Scart and Component).
Which is the best connection to use from the Sky box for best picture quality.? I need a cable with a 5m length.
Jeff.
JeffABall is offline
Old 26-06-2007, 6:58 PM   #2 (permalink)
JayCee's Avatar
Thanks: Gave 73, Got 741
Re: Sky Digibox Best TV Connection?
The only outputs available from a standard Sky box are RGB and PAL (Sky-speak for Composite video)...these are selectable within the Sky "Services", "System Setup", "Picture Settings", "Video Output" menu.
Note that the socket marked TV Scart is the only one which can output RGB which normally gives you a better/sharper picture compared to Composite video.
JayCee
Please note that any views expressed are my own personal opinions and not those of the AVForums
JayCee is offline
Old 27-06-2007, 2:13 PM   #3 (permalink)
Thanks: Gave 71, Got 11
I would also suggest that with such a long cable, you should get a good quality, well shielded one like this:
http://www.audiovisualonline.co.uk/d...t/display.html
http://www.audiovisualonline.co.uk/d...m/display.html
or better
Cheers,
Raj
___________________
LE40M87BDX|Sky+ SD|Sony STR-DA1200ES|Monitor Audio BR2s|Denon DVD-1930|Soundstyle Z2
rajivkotecha is offline
connection, digibox, sky
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
