Originally Posted by lexus123
It's a victorian terrace.
oldnewbie, thanks for your suggestion - not sure I could measure and mark that accurately and so would prefer to drill (very carefully!) straighthrough. I Kno wI need to get hold a particular (big) drill bit just don't know aht size/type
Before everyone tries to make this sound a bit too complicated for you, I will explain, I am a builder by trade that is why I tried to persuade you to do it the way I said ( Its neater ) But failing that all you have to do is open a door and measure from the outside surface to the inside surface ( all houses can be different ), And that gives you the thickness of the wall, Then add 2 inches for the drill chuck to hold and 2 inches to break through the wall ( ie my wall thickness is 11inch +2 + 2 = 15in but you wont get a drill that size it will be 16inch or40cm ) so you do the same and get the nearest size masonry drill that is just over your measurement. as far as thickness goes just cut off a 2inch section of cable ( after you have unscrewed the end off ) and take it to the shop and get a masonry drill the length you want but 3mm thicker than your cable.
hope this helps. ps cable installers will have a masonry drill that is about 50 to 60cm but for a one off install would be too expensive, so just follow my instructions and you wont go far wrong
