AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 04-05-2007, 10:44 PM   #1 (permalink)
SKY+ and purple images :)
Hi - first post but have been lurking for a while I have a question which i am hoping someone will know the answer to. Just bought a refurbished 26" acoustic solutions HD ready TV from ebay (oh dear you are thinking!). Its only as a second HD TV - got a 42" panasonic Viera as my main TV connected to SKY HD. The acoustic solutions tv has gone into another room and is connected to SKY+ via a magic eye (just so i can keep the box out of sight). Now the problem i have is that every now and again the black images on the TV go purple and fuzzy. If i switch the tv off and back on problem seems to go away - so in my mind theres a problem with the TV. However i was thinking that it may be due to the sky co-ax cables which i have been fiddling around with and was thinking that the image distortion i am seeing is due to that. Has anyone else had or seen details of this issue and whether its related to the co-ax cable and intermittent inteference? I think in know the answer - basically the TV is knackered . . .
tringo is offline
Old 05-05-2007, 11:14 AM   #2 (permalink)
Thanks: Gave 0, Got 299
Re: SKY+ and purple images :)
If you mean the coax cables to the lnb inputs - these would have no bearing at all on picture quality - with digital signals it is all or nothing - you would either get a picture or not ( on the borderline you will get severe blocky pixellation but not other distortions).
If connected by scart to the Sky dodgibox - try swapping the scart lead for a known good lead - try the present lead and dodgibox on your other TV to eliminate the scart lead and Sky box as being at fault.
Sky+ Pace PVR1,Sky+ Amstrad PVR3Sky Pace 2500, Fortec Star Ultra Diamond, Technomate TM9100, Fortec Star 5100 CI Diamond + Dragon CAM, Pace Twin view, Nokkia 9850 On Digital Box, Force DMaster 1122s, 2.8 ghz P4, Skystar2 PCI card, Artec USB Freeview box
davemurgatroyd2 is online now
images, purple, sky
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
