AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 04-05-2007, 8:53 PM   #1 (permalink)
Sky Plus Multiroom Problem
Hi I have Sky plus with multiroom. If I try and watch a recorded programme or live tv in the room where my second (old box) resides then the picture is poor.
Every other tv picks up the picture fine is just in the room with the old sky box in.
njewhu is offline
Old 05-05-2007, 11:23 AM   #2 (permalink)
Thanks: Gave 0, Got 299
Re: Sky Plus Multiroom Problem
If you are connecting both boxes to the problem TV by coax on the RF output - you almost certainly have interference between the RF outputs of the two dodgiboxes. Do you get a bad picture when you take the second box out of the circuit - merely connect the coax from the other room direct to the TV with the second box switched off at the mains? If the picture improves you will need to change the RF output channel of the dodgibox in that room. - "Services" "system setup " "0" "1" "Select" takes you to the hidden installers menu - just those buttons, no others and screen will not change until final select after "system setup". Option "RF outlets" change the RF channel number (anything between 21 and 68) and save and then retune TV to that channel - you may have to try this several times to avoid interference with terrestrial digital and analogue channels BUT you should be able to find one.
Sky+ Pace PVR1,Sky+ Amstrad PVR3Sky Pace 2500, Fortec Star Ultra Diamond, Technomate TM9100, Fortec Star 5100 CI Diamond + Dragon CAM, Pace Twin view, Nokkia 9850 On Digital Box, Force DMaster 1122s, 2.8 ghz P4, Skystar2 PCI card, Artec USB Freeview box
davemurgatroyd2 is offline
Old 06-05-2007, 8:37 AM   #3 (permalink)
Thanks for that I will give this a try.
Just to be clear In room 1 I have Skyplus ...works fine
I all rooms I can see the picture perfectly through a booster.
In the room that has the second digibox, I get a poor picture watching the recorded programme from the Skyplus.
cheers
njewhu is offline
Old 06-05-2007, 8:41 AM   #4 (permalink)
ok when i take out the digibox connected to the tv I get no picture at all!
njewhu is offline
Old 06-05-2007, 11:20 AM   #5 (permalink)
JayCee's Avatar
Thanks: Gave 73, Got 741
That's to be expected
You need to tell us how you have your digiboxes connected...by scart lead or RF etc?
JayCee
Please note that any views expressed are my own personal opinions and not those of the AVForums
JayCee is offline
Old 06-05-2007, 2:16 PM   #6 (permalink)
ok...
sky plus multiroom set up.
box 1 sky plus box in living room.
box 2 pace digibox
from the digibox i have a scart connection to the tv in that room and also a regular lead from the rf out to the tvs aerial socket.
I tried "bypassing" box 2 and connecting the coax direactly into the back but that made no differnce either.
I also changed the rf out on both boxes to diff channels but no differnce.
njewhu is offline
Old 06-05-2007, 4:19 PM   #7 (permalink)
JayCee's Avatar
In that case I would suspect a fault in your booster or downlead to that particular room.
JayCee
JayCee is offline
Old 06-05-2007, 10:27 PM   #8 (permalink)
really?
how else could i tell?
njewhu is offline
Old 10-05-2007, 9:25 PM   #9 (permalink)
Thanks: Gave 0, Got 5
you could try a sky plus combiner which feeds the rfout2's from the sky boxes onto 1 coax before the dist amp
derbyjj is offline
Old 11-05-2007, 3:44 PM   #10 (permalink)
Ok so this is not a multirrom problem as such basically bypassing the second skybox makes no differnece. So why then do I have a poor picture in one room and not the others?
What does a bosster look like and where would it be in my set up??
thx
njewhu is offline
Old 11-05-2007, 3:51 PM   #11 (permalink)
JayCee's Avatar
I think you should call in an aerial rigger and get it looked at.
Did you fit the cable to the other room yourself?
You already told us you had a booster so you should know what it looks like.
JayCee
JayCee is offline
Old 11-05-2007, 5:59 PM   #12 (permalink)
Guy coming in tomorrrow to test it
njewhu is offline
multiroom, problem, sky
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
