AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Digital TV Receivers and Services > Satellite TV > Sky and Sky+
LinkBack Thread Tools Display Modes
Old 04-04-2007, 8:59 PM   #1 (permalink)
Question Upgrading to Sky + Question
I dont fancy spending 170 on a Sky + box and installation. Can i just buy a Sky + box and then plug it into my existing wires/cables from my current Sky box?
I guess this cant be done but want to know before i proceed with looking for a separate recorder box
Moley RUFC is offline
Old 04-04-2007, 9:18 PM   #2 (permalink)
Phil57's Avatar
Thanks: Gave 39, Got 51
Re: Upgrading to Sky + Question
You need two feeds from the dish and a twin LNB before you can use a Sky+ box properly.
Phil57 is offline
Old 04-04-2007, 9:19 PM   #3 (permalink)
Thanks: Gave 2, Got 5
From what i understand you can just plug it into your existing cable. You will have to change to LNB to a quad LNB. Then you will also need to run an extra cable from the LNB to your Sky + box to enable you to use the Sky + facility, then you will need to inform sky and pair up the card to the new box, also pay the £10 extra per month for Sky + if you do not have 2 or more premium channels.
Hope this is what you were after.
If i am wrong please feel free to put me right.
JackL
JackL is offline
Old 04-04-2007, 9:35 PM   #4 (permalink)
Thanks for that. In which case would the 160 spent on a Sky + box and installation be better spent on a different make. Is it possible to get a decent recorder for less than 160? Would i then just use this like a VCR recorder and scart this into the Sky box and record from the on screen picture?
With other makes can you plan programmes like you can with a Sky + box though?
Old 04-04-2007, 10:34 PM   #5 (permalink)
Phil57's Avatar
I think you are asking silly questions, suggest you visit www.sky.com
Phil57 is offline
Old 05-04-2007, 7:52 AM   #6 (permalink)
Cheers Phil. Great help.
question, sky, upgrading
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
